#Camaro6
BeckyD @ James Martin Chevy
Old 09-20-2015, 11:26 PM   #1
Hypertrophy
Hypertrophy's Avatar
Drives: truck
Question Predicted upgrades in up coming ZL1 compared to 2SS
The 5th gen ZL1 differed from the 2SS primarily in suspension, drivetrain, and motor. You can now buy pretty much all ZL1 performance parts for your 2SS.
So what parts do you think will will be upgraded for the 2017 ZL1?
The LT4 is predicted and is already found in the Stingray. Any other parts or systems currently in the corvette that will make there way into the new ZL1?
Hypertrophy is offline   Reply With Quote
Old 09-21-2015, 01:39 AM   #2
Bhobbs
Bhobbs's Avatar
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle
Upgraded differential, half shafts and other suspension pieces. Obviously the wheels and tires. I'm sure they upgraded the fuel system for the LT4. Bodywork for cooling and aero.
Bhobbs is offline   Reply With Quote
Old 09-21-2015, 07:41 AM   #3
Jeffro19
Jeffro19's Avatar
Drives: 2018 ZL1 6M, Silverado High Country
LT4, upgraded suspension, wheels and tires, stronger rear diff, PDR, upgraded brakes, and different hood
Previous Camaro's - 2002 Z28 6 spd manual, T tops, Sebring Silver - 2010 2SS 6 spd manual, Cyber Gray Metallic
Current Vehicles - 2018 ZL1 Red Hot 6 spd manual, Carbon Hood, Sunroof
2019 Silverado High Country, Daily Driver
Jeffro19 is offline   Reply With Quote
Old 09-21-2015, 07:31 PM   #4
obzidian
obzidian's Avatar
Drives: 98 camaro turbo
Powertrain, standard mags, standard 2SS everything, wheel/tire... maaaaybe an e-diff which i doubt; I think its more likely the other camo'd 6th "1le" might get that instead of the zl1.
obzidian is offline   Reply With Quote
Old 09-21-2015, 11:32 PM   #5
Hypertrophy
Drives: truck
Post
Originally Posted by obzidian View Post
...standard 2SS everything, wheel/tire... maaaaybe an e-diff which i doubt; I think its more likely the other camo'd 6th "1le" might get that instead of the zl1.
It sounds as if the thought is the 2017 ZL1 will not differ as much from the SS as the 5th gen? Just some suspension and drive line parts and a blower? Will that be enough to justify the additional cost?
Also, am I wrong or was the 5th gen 1LE simply 2SS with some ZL1 suspension components? Is it anticipated that the 6th gen 1LE will have options not available on the ZL1 (i.e. E-diff)?
Old 09-22-2015, 09:27 AM   #6
Bhobbs
Bhobbs's Avatar
You are wrong.
Old 09-22-2015, 02:01 PM   #7
Hypertrophy
Drives: truck
Originally Posted by Bhobbs View Post
You are wrong.
I guess I should have been more specific. In addition to suspension upgrades you get wheels and tires, Tremec 6-speed, higher gear ratio, higher flow fuel pump/pickups.
Bhobbs I see that you drive one. What made you decide to go with the 1LE instead of the ZL1? That's probably really at the heart of asking what the differences are...
Old 09-22-2015, 05:06 PM   #8
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Mostly money I bet.
Most 1LE owners would like to have a ZL1 for the track. I got the ZL1 because I bought used and at a great price.
But the 1LE is a great track car. It really shines at the track for what little they cost in comparison to other cars out there IMHO.
Mods:
Old 09-22-2015, 06:25 PM   #9
hms2488485
hms2488485's Avatar
Drives: '17 Camaro SS 1LE
Any thoughts on prices?
hms2488485 is offline   Reply With Quote
Old 09-22-2015, 08:09 PM   #10
Hypertrophy
Drives: truck
Thumbs up
I've been very tempted to do the same thing... I was able to drive one like I stole it a the LV Moter Speedway a year or so ago. Got to compare mustang GT 500, Dodge Challenger (no hellcat then), and a ZL1 on the oval. They were all a lot of fun to drive, but there was just something about the tight handling and looking through that tank slit that I just love.
Old 09-22-2015, 08:31 PM   #11
Jeffro19
Jeffro19's Avatar
Probably around 62k to 65k
Old 09-22-2015, 09:24 PM   #12
Trans damm
Drives: Trans am
Performance data recorder will be available.
Trans damm is offline   Reply With Quote
Old 09-23-2015, 12:59 PM   #13
hognutz
hognutz's Avatar
Drives: 2013 ZL1
the 1le is a 2ss with some zl1 parts and some specific to it parts. it handles night and day above a 2ss though you would be shocked to drive them back to back.
the one thing that everyone forgets about the gen5 1le vs zl1 is the weight difference. I think they are ~300lbs apart and you feel it.
now that being said the 1le needs more power for me but some of the cars behaviors are good and even better because of the weight reduction.
I mean a 1le, cts-v/zl1 brake upgrade, some power mods will shock you just how good it is. it stops even better cause it's lighter, there is not power loss due to heat soak or just higher IAt's due to ambient temps.
on the street though the 1le is not as comfortable and the drive train is not as bulletproof to mods if you want to make say 600+whp
shopping for 2017+1le or zl1
2009 CTS-V -sold
2015 Hellcat-sold
2013 ZL1 -sold
2007 Z06- sold
2014 Chrysler 300
2011 Duramax 8" lift, deleted tuned
hognutz is offline   Reply With Quote
Old 09-23-2015, 01:16 PM   #14
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
There are no parts off the 5th gen ZL1 that are in the 1LE, there not the same car(this is for drive line, suspension, or brakes) sways are not the same, diff is not the same size, its all different.
Now to the OP, look for the new ZL1 to have much the same upgrades as the last gen did from SS to ZL1, hope the price comes in at under $67k but dont think it will, here is why, if it gets the LT4, that is a hand built motor, and a lot more pricey then the old LSA so we may get a new motor to help keep the price down, what do you think guys.
