Old 03-13-2014, 11:19 AM   #1
w2010abm
Drives: 69 camaro prostreet, 2010 abm 6m
how much oil does a LS3 take?
Just changed my oil and filter added 5 qts and showes low? What is the capacity of the LS3 after oil and filter change?
w2010abm is offline   Reply With Quote
Old 03-13-2014, 11:26 AM   #2
GMTool
MY SS is SOLD
GMTool's Avatar
Drives: AGM 2012 Camaro 2SS/RS L99
8 quarts. Put 3 more in. Hope your not driving it.
CAI, Dynatech Headers, HF Cats, JRE Tuned, Corsa Cat Back, Strut Tower Brace.
GMTool is offline   Reply With Quote
Old 03-13-2014, 02:03 PM   #3
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Only the four cylinder engines use 5 or less quarts. For future reference.
DSX_Camaro is offline   Reply With Quote
Old 03-13-2014, 03:11 PM   #4
rockrau
rockrau's Avatar
Drives: 2010 2ss red LS3
8qts.
rockrau is offline   Reply With Quote
Old 03-13-2014, 04:21 PM   #5
Synner
Drives: cars
Owner manuals are a fantastic reference when used.
Old 03-13-2014, 04:29 PM   #6
Devryn17
Suffers Fools Poorly
Devryn17's Avatar
Drives: 2010 SS/RS, CGM w/ Silver Stripes.
I think the capacity is officially called a "shit-ton" which, when converted, is 8 quarts.
2010 2SS/RS, CGM w/ silver stripes. Hurst Shifter, long tube headers, full exhaust, CAI, tune. SAE 407 RWHP/402 RWTQ
Momma didn't bronze my shoes, but when I turned 16 I inherited a lead foot.
Devryn17 is offline   Reply With Quote
Old 03-13-2014, 04:33 PM   #7
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
google, gm owners manual, forum search. and 8 qrts
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 03-13-2014, 04:45 PM   #8
MYDLIFECRISIS
MYDLIFECRISIS's Avatar
First time the dealer changed mine, they only put in 6. I didn't check it till I got home. I bought two more, put them in, drove back to them to bitch and get reimbursed for the two quarts. I figured they knew the SS took 8!
MYDLIFECRISIS is offline   Reply With Quote
Old 03-16-2014, 06:32 AM   #9
Indydriver
Drives: '14 2SS/RS Vert 6M/KTU/NPP/DTA/ARH
How do you conduct an oil change without knowing how much oil to put back? Didn't the 5 qt pan you drained the old oil into overflow all over your garage floor?
Seriously, you really shouldn't be touching anything under the hood.
Consensus is, by definition, a lack of leadership.
Indydriver is offline   Reply With Quote
Old 03-16-2014, 06:54 AM   #10
TrekGTO
TrekGTO's Avatar
Drives: 05 GTO / JETTA TDI
Wow 8qt synthetic, I thought 6+ on the LS2 was expensive! Seriously look @ some of the diesels take 2x that and the big trucks forget about it. With all the changes in oils and such service is getting crazy.
We do a 12qt transmission flush recommended every 30k miles it can get very expensive with Dex VI. I know manufactures say never change ATF but I can say first hand when you see how bad the old fluid looks I'm a believer in flush. 30K may be soon for synthetic ATF but with a rebuild often costing more than the value of the car its a good investment.
TrekGTO is offline   Reply With Quote
Old 03-24-2014, 05:11 PM   #11
Misfit
Jumpmaster
Misfit's Avatar
Drives: 2014 Camaro SS LS3
GM says oil capacity is 8 qts, I only add 7 quarts then start it, let it warm up then let it settle and check the levels, add more as needed. If you add 8 qts you run the risk of overfilling the oil because the oil capacity includes oil stuck in the cooler and other places that does not drain out. Just an FYI. I gained my info from Ted Jannetty.
Danny
2014 1SS Ordered 18 SEP 13 Delivered 25 OCT 13 Picked up 30 OCT 13
CAI Intake, VMAX Ported Throttle Body, Apex Motorsports Catch Can, Apex Intake Scoop/Washer Bottle Relocate, Skip Shift Eliminator, Stainless Works 2" Headers, High Flow Cats, Retro Catback Exhaust, JRE Tune...more to follow
12.6087 1/4 ET @ 113.98MPH on stock tires.
Misfit is offline   Reply With Quote
Old 03-31-2014, 11:14 AM   #12
SSGUNNER
Chu no guat a hasa is?
SSGUNNER's Avatar
Drives: 14 Jeep G Cherokee Overland HEMI
I've seen it can hold up to 8.6 qts. I've always put 8. Dealer tried to charge me for 9 qts's.
11 2SS/RSL99No Longer Stock (Sold) 6/19/14:AAC Plasma DRL's | Plug n play harness | Elite CC | Tint: 35% & 5% | LED Dome light | Show-N-Go Plate Holder | Flowmaster AT | C.A.I. Intake | VMAX CNC Spiral Ported TB | Husky Splash Guards
SSGUNNER is offline   Reply With Quote
