Old 08-28-2017, 01:53 PM   #1
Roadking107
Drives: Camaro ZL1
2014 ZL1 cuts out at WOT
Hi
I’m new to the forum. I just picked up a 2014 ZL1 automatic. When trying to drag race the car it cuts out at wide open throttle in both Perf traction 5 race and with everything off. I would have thought that with the nannies off the tires would spin and the car would upshift but it acts like it’s hitting the rev limiter. Any ideas or suggestions?
Roadking107 is offline   Reply With Quote
Old 08-28-2017, 02:16 PM   #2
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
Hey. Welcome.
More specifics? Cuts out to what rpm? How long have you had this Z? Any mods?
If you hit the limit the ecu will kill for a second.
JB'sZL1 is offline   Reply With Quote
Old 08-28-2017, 03:31 PM   #3
Roadking107
Drives: Camaro ZL1
I've had the car about 2 weeks. No mods bone stock. The first time it cut out around 5K rpm. 2nd time around 4500 rpm. It's an automatic why isn't it upshifting it shouldn't hit the rev limiter
Old 08-28-2017, 04:24 PM   #4
JB'sZL1
No codes? You have a problem if the throttle is closing at 4500 rpm.
Old 08-28-2017, 04:58 PM   #5
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
Since you bought it used, it's possible the car was modified and was tuned, and was thrown back to stock to sell with the tune still on it. That would definitely cause issues. See if your dealership can reprogram the car to stock calibrations assuming it's 100% stock now.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 08-28-2017, 05:05 PM   #6
Roadking107
Drives: Camaro ZL1
No codes
Old 08-28-2017, 05:51 PM   #7
San2cci
San2cci's Avatar
Drives: 2013 silver ice metallic ZL1
Is this only happening in tapshift mode (manual mode)?
San2cci is offline   Reply With Quote
Old 08-28-2017, 06:13 PM   #8
Roadking107
Drives: Camaro ZL1
No I had it in drive. If I use the paddle shift if I shift early it seems o.k
Old 08-28-2017, 07:34 PM   #9
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
Isn't it still under warranty?
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 08-29-2017, 08:44 AM   #10
NVRL8 ZL1
W8NN4U
NVRL8 ZL1's Avatar
Drives: '13 ZL1 A6
It's the traction control module, have your dealer look at it. After I added the upper pulley, mine would do the same thing when I floored it in drive or sport mode at around 3800-4500 rpm. Turning off the nanny's should have fixed it, so the module may have issues.
NVRL8 ZL1 is offline   Reply With Quote
Old 08-29-2017, 12:04 PM   #11
ABADZL1
ZL1 Pilot
ABADZL1's Avatar
Drives: 2013 ZL1
Is your speedo gauge fluctuating when this happens? Or any other gauges?
GP Tuning 2.5 Cam, RPS Carbon Twin Clutch, Ported Blower, Kook's Headers, Cold Air Inductions CAI, ID850's, 9.17 Lower, 2.5 Upper, JMS BAP, Pedders Front Radius Arm Inserts, Whiteline Subframe Inserts, Tuned by me with HP Tuners
Idle Clip Link...........https://www.youtube.com/watch?v=gTL8S9eHwbs
ABADZL1 is offline   Reply With Quote
Old 08-29-2017, 01:55 PM   #12
Roadking107
Drives: Camaro ZL1
Power train should still be under warranty
Old 08-29-2017, 01:57 PM   #13
Roadking107
Drives: Camaro ZL1
I didn't notice any gauges fluctuating
Old 08-29-2017, 01:59 PM   #14
Roadking107
Drives: Camaro ZL1
It does act like the traction control is coming on or acting like its hitting the rev limiter. I guess I'll take it to the dealer
