01-09-2011, 06:20 PM | #1 |
Drives: 2010 Camaro SS (LS3, 150-Shot N2O) Join Date: Jan 2011
Tranny Problems
Has anyone else had tranny problems with a 6spd? If so what do you think this is..
I was driving around yesterday and when I whould shift from second to third the shifter would be in the third gear position but it would engage first gear. Then later in the day it suddenly whouldn't go into 2nd. I'd put the shifter in second but it wouldn't be in gear. (it would only do this randomly. about 1/3 of the time) Finally after I had to yank the shifter out of the 1st gear position I lost every gear.. only way I got the car out of the middle of the intersection what after I put the shifter in reverse I managed to get 3rd gear. After that I couldn't even get 3rd gear back. The car was towed to the dealership. Hoping someone had some insight as to what the issue was. (might save the dealership time in fixing it.. cuz i really want my wheels back) I got the car w/ 15,800 on it and it had 16,600 on it when they towed it 3 days after I left the dealership with it. |
01-09-2011, 06:23 PM | #2 |
Not sure, but it might be the syncros, or maybe your shifter is loose.
01-09-2011, 06:27 PM | #3 |
Drives: 2011 chevy camaro LS Join Date: Oct 2010
Take it back to the dealer sounds like a warranty issue. I couldn't go in reverse so I took it to the dealership and got a brand new transmission warranty problem
01-09-2011, 06:30 PM | #4 |
it was towed to the dealership but they won't be open till monday. and it just started snowing here.. and since it rarely snows here everyone starts going crazy and all.. (avoid walmart in arkansas if it is about to start snowing.. you'll get trampled) i have a feeling that it might be late monday or tuesday before it gets started on.
01-09-2011, 06:57 PM | #5 |
Drives: 2011 CGM 2SS/RS A6 Join Date: Sep 2010
Lesson learned... check for that adam's apple first.
01-09-2011, 07:00 PM | #6 |
Drives: 11 2SS/RS, 56 Chevy Bel Air 2DR HT Join Date: Dec 2010
I agree with the shifter being loose, or the synchros. Hopefully its just the first one and you will be back on the road shortly.
01-09-2011, 07:09 PM | #7 |
el Ruco
Drives: 2010 Camaro SS (now runnin' TENS ) Join Date: Nov 2009
My transmission broke due to a shitty output shaft bearing. When it gave out, the metal dropped into the gears like a bomb exploding.
01-09-2011, 07:14 PM | #8 |
I dont' see it being syncros.. I'm thinking shift linkage or main shaft inside the tranny (the one that works the the shift forks)
01-09-2011, 07:20 PM | #9 |
Sounds like either synchros or linkage. Did it have an aftermarket shifter in it when you bought it? Something might have come loose. The dealer will sort it out.
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
01-09-2011, 07:27 PM | #10 |
Stock shifter.. it was demo car i believe.. it was purchased at the dealership and the car was sitting on the "New Car" side of the lot
01-09-2011, 07:49 PM | #11 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
A good trans tech will be able to take care of it. Sounds like an internal problem, maybe a bent shift fork. Should be no problem for a tech with Tremec experience. There is really no way to speculate what is wrong other than a tech digging into it.
01-09-2011, 11:11 PM | #12 | |
Drives: 2010 cgm LS Join Date: Oct 2009
01-09-2011, 11:30 PM | #13 | |
Dude you bought what you call a "new" car with 15,000 miles on it (I saw your other thread). No "demo" car has 15,000 miles, I hope you didn't pay more than 20k for this car. Especially since for some strange reason someone put a V6 fascia on it (I know some folks don't care for mail slot and change it out, but a dealer wouldn't do that. Makes me wonder if it was in an accident). Good luck either way though.....
01-09-2011, 11:34 PM | #14 |
Drives: 2011 2lt rs Join Date: Dec 2010
Similar Threads | ||||
UNOFFICIAL CAUSE OF TRANNY OUT PUT SHAFT ISSUE | orangeinfernoman | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 38 | 04-25-2011 08:25 PM |
Give me some typical signs of an A6 tranny going out. | bumblebeecamaro | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 0 | 05-09-2010 07:21 PM |
Consolidated Toyota Recall/Safety thread | Rallysport | General Automotive + Other Cars Discussion | 382 | 03-01-2010 05:42 PM |
Camaros with M6 transmission still being produced? | Halo2 | Camaro Price | Ordering | Tracking | Dealers Discussions | 362 | 07-15-2009 11:43 AM |
M6 Tranny production problems official? | Treadstone | Camaro Price | Ordering | Tracking | Dealers Discussions | 1 | 07-13-2009 01:55 PM |
