03-07-2014, 12:19 AM | #1 |
Caffeine Injected
Drives: 13 Ram - 05 Widebody 1050rwhp Vette Join Date: Sep 2010
For Sale FRONT SS R1Concepts Double Drilled / Slotted Rotors
Selling x2 Front R1Concepts Double Drilled / Slotted Premium Rotors
Have probably about 1000 miles on them or less. There is some surface rust as seen in pictures from them sitting, just like rotors would rust if you don't drive you car for a couple days. Only selling because I did a 6 piston conversion. $165 Shipped, paypal or local deal. US Buyers only please. Please allow me 1 - 2 business days to ship. Last edited by nitto85; 03-18-2014 at 07:08 PM. |
03-08-2014, 02:36 PM | #2 |
Caffeine Injected
Bump.
03-09-2014, 04:01 PM | #3 |
Caffeine Injected
Bump.
03-10-2014, 05:41 PM | #4 |
Caffeine Injected
Bump.
03-11-2014, 08:59 PM | #5 |
Caffeine Injected
Bump.
03-13-2014, 04:13 PM | #6 |
Caffeine Injected
Bump.
03-15-2014, 12:55 PM | #7 |
SoCaL MaYheM oR NoThInG!
Drives: 2010 Camaro 2SS L99 Join Date: Oct 2012
fronts or backs? what did you do with the other 2?
03-15-2014, 02:16 PM | #8 |
Caffeine Injected
Oops, they are Fronts, I did a 6-piston conversion on the front and could no longer use these, the rears are still on the car.
I should say this is the second vehicle I have bought R1 concepts rotors for, I've never had a complaint really and probably will look to them first for my next vehicle. |
03-16-2014, 09:12 PM | #9 |
Caffeine Injected
Bump.
03-16-2014, 11:45 PM | #10 |
Too much is never enough!
is that a reflection in the photos or are they Blued?
03-16-2014, 11:48 PM | #11 |
Caffeine Injected
03-16-2014, 11:57 PM | #12 |
pm sent
03-18-2014, 07:07 PM | #13 |
Caffeine Injected
03-19-2014, 12:59 AM | #14 |
Drives: 2010 camaro 2SS/RS Join Date: Aug 2011
PM sent
