Old 08-16-2014, 12:55 PM   #1
inferno camaro
inferno camaro's Avatar
Drives: 2010 camaro pace car, 2008 cts bl,
1 piece driveshaft
Does any one know of a company other than dss that makes a driveshaft for our cars and how is the quality?
Also I have a dss aluminum auto driveshaft I may sell.
Mods, 2r max cam, ls3 conv,kooks lt w/hf cats,kooks street sleeper cat back with magnaflow res x-pipe, roto fab cai, v-max TB, vigilante 3700 stall, 3.70 LPE, 442hp/392tq, Mike Norris Tune 11.71@116.24 1.63 60' m&h DR's
inferno camaro is offline   Reply With Quote
Old 08-16-2014, 01:34 PM   #2
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
Gforce sells Dynotech one-piece shafts. I have their 3.5" aluminum shaft and it seems to be of great quality. I was going to get one from DSS, originally, but the turn-around tine to get one was unacceptable.
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq
fldrummer is offline   Reply With Quote
Old 08-16-2014, 03:20 PM   #3
Synner
Drives: cars
My gforce has been great. Smooth as glass to 150.
Old 08-16-2014, 03:42 PM   #4
inferno camaro
Nice!!
Old 08-17-2014, 09:55 AM   #5
GFORCE1320
Drives: 05 GTO
Yea guys, our turn around time is about 5 business days to get it made.
GFORCE1320 is offline   Reply With Quote
Old 08-17-2014, 10:30 AM   #6
Kopterman
Kopterman's Avatar
Drives: 2014 Bright Yellow 2SS/RS
What is it you don't like about the dss driveshaft if I may ask?
Kopterman is offline   Reply With Quote
Old 08-17-2014, 11:19 AM   #7
inferno camaro
I've installed it and it seems to have a vibration above 75 or so. I pulled it out and sent it to DSS to have it checked over and they changed the cv and checked balance on it (no charge to me and I bought it used) I reinstalled it and still has a vibration so I'm not sure if I have a problem somewhere else or what is going on. I cant hardly believe something is wrong with the shaft as they have checked it out twice. Maybe I'm to sensitive to any vibration. I have no complaints as they have gone out of the way to fix the problem.
Old 08-17-2014, 01:30 PM   #8
T-r3x
Drives: 2010 camaro ss ( LS3 )
Why do people change their drive shaft to a single piece drive shaft?
T-r3x is offline   Reply With Quote
Old 08-17-2014, 07:54 PM   #9
inferno camaro
I got one because of pictures I saw of some cars busted up underneath from a broken 2 piece. I don't know how much of an issue it actually is.
Old 08-18-2014, 12:13 AM   #10
H-E
Drives: 2010 zr1 Camaro 2011 vert
Did you check your measurement with the cv?.You can call me if you want, I think I have another shaft you can try .We have tried every type of shaft when the 5th gen first came out and the cv shaft was by far the best .I can't say right now what your problem is but that style cv shaft isn't it.Give me a call and I'll try to get you sorted out.
H-E is offline   Reply With Quote
Old 08-18-2014, 02:13 AM   #11
T-r3x
No increase in performance?
Old 08-20-2014, 02:26 PM   #12
RaiderSS
RaiderSS's Avatar
Drives: 2010 Camaro SS2 DeadBLK
Lighter in weight.
Improves throttle response by eliminating lag from rubber isolators and pivot in the factory drive shaft.
Stronger than factory configuration which has been known to sheer bolts at the diff.
RaiderSS is offline   Reply With Quote
