02-28-2014, 12:12 AM | #1 |
Drives: 2018 Camaro 2SS, Garnet Red Join Date: Jan 2014
Octane booster additive on an LFX?
Have a buddy who traded in his GTO for a Ford Focus, he gave me a bottle of Lucas Octane booster which contains MMT.
I had been told that the LFX tunes itself to the higher octane, but does that apply with stock tune above 93 octane fuel level? Went and added it today during fillup of Chevron 91. Pros and cons of this? He gave me a box of 4, he used to add it with 87 to boost his octane without paying for California Premium. |
02-28-2014, 09:30 AM | #2 |
Drives: 2014 LS2 Join Date: Feb 2014
MMT is in't so good to use on an emission controlled vehicle.
The main reason is that it tends to contaminate the O2 sensors and catalyst when used in effective concentrations. In order to get any meaningful octane boost with MMT and premium fuel you will have to add amounts that can aggravate the contamination issue. Keep in mind that when a manufacturer says his product raises octane 2 points this really means .2 not 2 whole numbers. May I reccomend Toluene or Xylene? These both are already used in some (most?) premium fuels. I have added both in the past with no issues whatsoever. (tuned 07 Solstice GXP 24 PSI boost) with very positive results (13.02 107 1/4 mile) These petro chemicals are generally available at paint supply houses. 1 gallon usually costs @ $20 around here (NC). Toluene and Xylene both have octane numbers in the 120 range. http://vanilla47.com/PDFs/Toluene/BE...0octane%29.pdf http://www.bp.com/retail/liveassets/...nd_PowerV2.pdf http://en.wikipedia.org/wiki/Octane_rating On my stock LFX I only see a little knock retard with 93 V-Power. I see a lot of Knock Retard with 87 even with less spirited driving. It is possible that in my instance more octane over 93 would only give minimal gains in performance. YMMV. Does any one sell "Track Tech" UNLEADED street legal fuel in your area? http://www.cpchem.com/bl/specchem/en...lications.aspx This fuel is good as an additive or in pure form. Stay away from leaded fuel as it will wreck all of the emissions controls that are in the exhaust stream and prematurely foul your plugs ETC.! I don't recommend MMT either for the reasons stated above. Cut and paste from 2014 Camaro owners manual Chapter 9 page 51: "Some gasolines that are not reformulated for low emissions can contain an octane-enhancing additive called methylcyclopentadienyl manganese tricarbonyl (MMT). Do not use gasolines with MMT as they can reduce spark plug life and affect emission control system performance. The malfunction indicator lamp may turn on. If this occurs, see your dealer for service." Someone will probably chime in saying our LFX engines were designed for 87 and more octane is a waste of money. Horse feathers!!! It's an 11.5 to 1 compression ratio engine! I have the data logging to prove that LFX will make better efficiency and more power with 93 Vs: 87. Our engines will TOLERATE low octane fuels by virtue of having a knock sensor, direct injection, computer engine management, Etc. The jury may still be out on any gains above 93 octane with a stock LFX engine. I hope this is helpful. Good day. Rickey. Last edited by Xmitterengineer; 02-28-2014 at 10:54 AM. Reason: Typo |
02-28-2014, 10:42 AM | #3 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Even on 101 octane, the Gretchen car only made slightly more power, and that was twin turbo. Stick with 93 octane.
02-28-2014, 11:04 AM | #4 |
DSX Greetings.
Was that 101 octane determined by R+M/2 , research, or motor octane? There are differences. http://qcwo.com/technicaldomain/what-is-octane-rating Just curious. Rickey. |
02-28-2014, 11:17 AM | #5 | |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
Thankyou so very much.
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
02-28-2014, 12:40 PM | #6 | |
02-28-2014, 12:46 PM | #7 |
So should I stretch the other 4 Lucas Additives he gave me with a tank of 89 for 96 octane or should I just save these for a rainy day.
02-28-2014, 01:50 PM | #8 |
02-28-2014, 02:40 PM | #9 |
02-28-2014, 03:06 PM | #10 | |
Just my 2 cents discounted to free, so take it for what it's worth. A can of MMT based additive once in a while probably will not harm anything. A steady and heavy diet of MMT however is asking for trouble IMHO. Rickey. |
02-28-2014, 04:12 PM | #11 |
That's good news; I was given this stuff for free and I wouldn't foresee myself purchasing this on my own volition.
02-28-2014, 04:25 PM | #12 |
Drives: 2002 Z/28,1968 Chevelle convert. Join Date: Oct 2010
Correct me if I am wrong but doesn't the "octane boosters" just add 1/10th or 2/10ths of a percent of 1 single octane rating ?? ...
02-28-2014, 05:50 PM | #13 | |
02-28-2014, 06:26 PM | #14 |
Check this formula out.
Up to 60 points octane boost!!! http://www.permatex.com/documents/TD...tive/12010.pdf It is "designed for racing use only" and has nitromethane in it. Of course it doesn't say how much nitro is in it. Tried some of this in my weed whacker once.....weeds flew! Really. Rickey. |
