04-05-2015, 05:17 PM | #1 |
NEcamaro5
Code p0335 crank sensor
Did a header install and now I have a P0335. Dose any one know where this sensor is. I'm hoping it's on the drivers side buy the first cylinder. This got bumped a few times. Here is a pic of the sensor I'm hoping will fix the prob
04-05-2015, 05:29 PM | #2 |
NEcamaro5
I did find that the sensor in question looks like this pic.
04-05-2015, 09:34 PM | #3 |
Drives: 2SS RS ABM A6 Join Date: Jun 2010
The sensor you're showing is a coolant temp sensor.
I'm not a 100% sure, but I think the crank sensor is above the starter.
Jack Bilger
04-06-2015, 05:02 AM | #4 |
NEcamaro5
Yea. I found the sensor and your right it's behind the starter and heat shield. So tonight I'm going to take that apart. I think that when I went to put the dip stick back I got a one in a million shot and popped the clip off.
04-06-2015, 07:59 PM | #5 |
Drives: 13 blue ray zl1 Join Date: Apr 2015
check to see if the harness is up against the header primary and shorting it out
stock for now blue ray 13 zl1 m6
04 cts-v. cammed, headers, exhaust, intake, suspension 92 lexus sc300. singled 2jzgte swapped 07 tbss basically stock 00 built z28. 520 rwhp, 5.7, no power adders |
