07-05-2015, 01:56 PM | #1 |
Drives: 2010 SIM 2SS/RS Join Date: Aug 2014
Question about L99 with Aftermarket Cylinder Heads
I would like to know some of your guys opinions on compression ratios for L99's with Aftermarket heads. I have a set of TFS Gen X 255's being worked by Tony Mamo as we speak. I will be running 93 octane pump gas. I have confidence in my tuner but want to stay in a "safe zone" with the increased comppression.
CAI intake, TSP long tubes, custom exhaust, 1LE gears, tuned by Greg's Tunning Operation.
07-05-2015, 03:29 PM | #2 |
Master ASE, GM, LSX Tech.
Drives: 2010 Camaro SS Join Date: Oct 2012
How much are increasing the compression?
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray 480 RWHP 452 RWTQ + Nitrous Express 150 Shot |
07-05-2015, 03:41 PM | #3 |
Also depends on cam choice. Dynamic compression plays a huge roll.
I've seen plenty of LS cars run 11.5-12.0. They just may take a bit less timing. I think 11.5-11.8 is a good range for NA compression.
Nick
Corvette Z06 -1200ish rwhp |
07-05-2015, 05:27 PM | #4 |
Drives: 2010 2SS/RS Join Date: Jun 2009
Have ls3 heads done by lpe at 11.4
07-05-2015, 05:48 PM | #5 |
11.5 is what was suggested. I will be running a mid-size vvt cam not definite on specs yet. I'm thinking 11.5:1 may be a little too aggressive on the street running pump gas. I was just curious as to what other members are running.
07-05-2015, 06:18 PM | #6 |
11.5 is fine with pump gas.
Nick
07-05-2015, 07:08 PM | #7 |
Drives: 2013 SS Join Date: May 2013
I'm 11.5:1 on 93 pump gas even a buddy runs 12.5:1 on pump 93 on his
07-05-2015, 10:49 PM | #8 |
Should have listed more info. 11.4 on 93 pump with tsp vvt2 cam which is pretty mild i believe.
