Old 08-25-2013, 12:41 PM   #1
Bargeratt
Bargeratt's Avatar
Drives: ZL1, Rally Yellow
What am I doing wrong?
Took the car out for just fun down a back country road. In my other camaro I could come out in first holding the brake and gas and smoke the tires. Now with my ZL1 it is just bogging down like it want to cut off of just grab to tight on the road to spin the tires. And was in PCM 5. I would of thought I could of covered the field with smoke but all I got was a stall.
Guess I am just a loser
Bargeratt is offline   Reply With Quote
Old 08-25-2013, 12:45 PM   #2
G-Oil Guy
Where am I?
G-Oil Guy's Avatar
Drives: Zoe the ZL1, 2012 Frontier
Even in PTM5 I think the launch control and traction control are on. If you read the owners manual it will tell you how to turn everything off. With everything off you should be able to get the results you want.
FOR SALE: 2013 ZL1 Message me if interested
G-Oil Guy is offline   Reply With Quote
Old 08-25-2013, 12:54 PM   #3
MPR
MPR's Avatar
Drives: 2013 Camaro ZL1
Turn PTM all off
http://www.camaro5.com/forums/showthread.php?t=247089
LSA VR38DETT 4B11 2ZZ-GE-SC N55 B18C5 302
MPR is offline   Reply With Quote
Old 08-25-2013, 01:18 PM   #4
KLR ZL1
H-Town Camaro Club Member
KLR ZL1's Avatar
Drives: 17 Hyper Blue Metallic KLR-ZL1
Is it a manual or automatic?
KLR ZL1 is offline   Reply With Quote
Old 08-25-2013, 01:36 PM   #5
Nemisis
Drives: 2013 Ashen Gray Metallic-M6
Yes, even in ptm modes it still holds it back. Push down on the button and hold for about 7 seconds and it turns them all off;-)
2013 AGM m6 zl1-airaid cai, 9.55" crank pulley and jre tuning, 2" tsp longtubes, FAST 85lb injectors...630/627
Nemisis is offline   Reply With Quote
Old 08-25-2013, 01:37 PM   #6
Bargeratt
Bargeratt's Avatar
It is a manual. Ok I turned it all off. I got some but not what I thought. Think maybe this road is one of those hard porous roads. Did almost do a doughnut on a narrow road so thought that is enough for today.
Old 08-25-2013, 04:09 PM   #7
MichaelH
SOCAL HT5
MichaelH's Avatar
Drives: 2013 BRM ZL1 M6
Tires to sticky? Lol
2013 ZL1 M6 - Mods-in the works
Old vehicles
2010 CGM Camaro (sold)
Other Vehicles:
2008 Kawasaki ZX6R-115 RWHP in mid summer
2006 Chevy Trailblazer SS- For Sale; Lots of extras
MichaelH is offline   Reply With Quote
Old 08-25-2013, 04:10 PM   #8
AWSME SS
AWSME SS's Avatar
Drives: 2015 Cummins
Add trick fuel.
AWSME SS is offline   Reply With Quote
Old 08-25-2013, 04:50 PM   #9
DavidW
Drives: 2013 ZL1 Vert Auto IOM
Pull the abs fuse that should disable everything as far as I know
DavidW is offline   Reply With Quote
Old 08-26-2013, 03:25 PM   #10
zirotti
zirotti's Avatar
Drives: 2013 ZL1
lolz
zirotti is offline   Reply With Quote
Old 08-26-2013, 03:28 PM   #11
pumpkinrancho
COMPULSIVE CAMARO OWNER
pumpkinrancho's Avatar
Drives: 18 ZLE,14 2ssrs,96,73 RS LT,69&67
Here is the skinny on a burnout in a manual. Just hit the button once, the yellow traction control light(yellow) will come on. Roast away. Anything else will put you in a ptm mode and limit tire spin.
Old 08-26-2013, 03:41 PM   #12
Whos_Drivin
Drives: '12 Camaro ZL1, '16 Silverado Z71
Unless you're rolling forward and the back end starts to go sideways...you don't have to be rolling fast and the stabilitrack kicks in. Holding the button for 7 secs turns it all off.
2012 ZL1: M6, Rotofab CAI, ATI balancer w/8.66 overdrive, PFADT long tube headers w/cats
2016 Silverado LTZ-Z71 Midnight Edition: 6.2L, 8 speed auto, Borla exhaust
Whos_Drivin is offline   Reply With Quote
Old 08-26-2013, 09:28 PM   #13
qniknam
Drives: 13 ZL1 | 13 SRT GC | 13 SRT CHARGER
Bro you gotta do a W with your gears 1, 2, 3, 6, 5 and it will says "Achievement Unlocked" on your HUD then launch control is enabled.
qniknam is offline   Reply With Quote
Old 08-26-2013, 10:06 PM   #14
OldScoolCamaro
...in race mode PTM 5, one must depress the gas pedal and hold it to the floor while the steering wheel is straight, and the tranny is in first gear with the clutch fully depressed <stick>. The motor will hit the rev limiter, bounce a bit, and after a few seconds settle down to around 4K rpms or so....then you are ready to launch. Ease off the clutch and blastoff. That's launch mode. You can't pick the rpm launch point in any PTM mode, the computer must. If you try to, the engine noses over, bogs, dies, and will only recover once you lift off the throttle. In plain tour or sport mode with no PTM you can pick rpm launch. Get accustomed to that before the ultimate trick, turning off the nannies and launching..at any rpm. But, all safeguards are off, and it's only you and the car. Black diamond hill.
