03-12-2021, 08:28 PM | #1 |
Drives: 2015 1le Join Date: Feb 2021
Suede cleaning steering wheel and shifter
Previous owner didn't take very good care of the interior. I worked on cleaning up the suede and found that mother's vlr and scrubbing with a microfiber towel works pretty good at working the dirt out of the suede and making it soft again
03-12-2021, 09:03 PM | #2 | |
Drives: 2014 2SS/RS 1LE Camaro&16 Silverado Join Date: Aug 2013
Sent from my SM-N950U using Tapatalk
Z28 Brake ducts, CAI & Tune
"Never let fear decide your fate!" |
03-13-2021, 11:25 AM | #3 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
It is not suede ,it is synthetic 98% polyester 32% polyurethane . It is in fact called Alcantara ,in other words it is a form of plastic . A stiff brush and some water works fine .
OLD GUY FLYING FAST AND LOW
03-13-2021, 03:22 PM | #4 |
Drives: 2015 Black rs/ss/1le Join Date: Apr 2018
I add a few drops of woolite dark to wam tap water. I soak a micro fiber towel in the solution, wring it out then drape the towel on the wheel for a few minutes to break up the oils and grime. I then gently wipe the area, rinse and repeat.
Once everything is clean, I do a final wipe down with just warm water. Woolite has a slight fragrance that will dissipate after a few minutes. You do not want to apply a lot of pressure when rubbing. |
03-13-2021, 09:57 PM | #5 |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
I just use a tiny bit of dawn and hot water on a microfiber and get it just barely damp, then dry it with another microfiber which stands the fibers back up and gives it the suede feel again
UPSTATE C5 MEMBER
03-14-2021, 09:36 AM | #6 | |
Drives: 2014 1SS/1LE Join Date: Nov 2015
03-14-2021, 09:48 AM | #7 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
I just used a damp rag and went to town. Should really drive the car with gloves on.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
03-14-2021, 10:43 AM | #8 |
Just wash them dickbeaters
UPSTATE C5 MEMBER
03-14-2021, 12:16 PM | #9 |
03-15-2021, 01:01 PM | #10 |
I always washed my hands B4 driving the car , so mine never got too dirty to begine with.
