09-02-2016, 09:21 AM | #1 |
Drives: 2013 LS Join Date: Feb 2016
Loosing Engine Oil
Ok guys, here is a question, how much oil does your engine looses on a regular bases? I have a 2013 with about 60K on the odometer that I need to add about a quart every 500-600 miles. I checked the engine bay and its dry as a bone. I have never seen any oil stains under the car either. Seems a bit excessive to me.
Also, not sure if it makes a difference but I've installed Elite II catch can and do see some oil in it but not nearly close to a whole quart. Looking for suggestions as to what it might be. Thanks, Alex |
09-02-2016, 09:27 AM | #2 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
2013 1LS, not losing enough oil to pop open a quart bottle between oil changes. Change my oil every 4,000-5,000 miles.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
09-02-2016, 10:45 AM | #3 |
Drives: 2013 Camaro 1LT RS Join Date: Jan 2016
I haven't had to add oil between changes.
09-02-2016, 10:52 AM | #4 | |
Drives: Camaro Justice Join Date: Jun 2007
09-02-2016, 10:57 AM | #5 |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
Depends how you drive, if you always go full throttle. I don't lose close to that much. If you're running synthetic you can try conventional and see if you lose less. No smoke from the tailpipe at all right?
That's not even bad. Probably normal actually, especially if you're using synthetic. |
09-02-2016, 03:37 PM | #6 |
Drives: 2013 v6 auto 1LT Join Date: Oct 2012
how long you have the 13, new? sounds like a bad ring set. i have read from good tecs Tracy at rx talks a bout it ,the window to get a good ring set is 0-300 and drive hard ect. no second chance
09-03-2016, 05:02 PM | #7 | |
SHKE BKE
or at least this has been my experience. And besides that, this is why everyone should check their own oil levels at least once a month or once every 500 miles And you said half a quart every 5,000 miles, not 500. Lol, half quart every 500 is a bit too much to burn yeah. But GM won't agree. Toyota certainly doesn't. They issued a recall for the 4 cylinder Rav4s. My girlfriends 07 Rav4 burns oil like crazy and they have a recall to rebuild it when that happens, but they have to verify first. They say as long as it's not burning over 2 quarts every 1000 miles it's fine... Which it does burn over that, and they claim it didn't. And it burns even more on synthetic |
09-03-2016, 05:49 PM | #8 |
Drives: 2013 1LT RS Camaro Join Date: Apr 2016
Have never had to add oil, I change it at 3,000-4,000 interval. It's never been lower than a half qt. Mobil 1.
09-03-2016, 05:53 PM | #9 |
He's going through an excessive amount of oil, is the warrenty still effect? 13 is 5years on the drive train, right?
09-03-2016, 05:59 PM | #10 |
I think your right. 5 year or 50,000 miles. Not positive, that's why I asked. Or is it 60,000?
09-03-2016, 06:03 PM | #11 |
Somethings up , he dropping a lot of oil.
09-04-2016, 10:39 AM | #12 |
Drives: 2013 Camaro 1LS - Ashen Gray Join Date: Jan 2015
I work at auto shop and just Friday I was on pro demand which is Part of Mitchell's and some Tsb's from Chevy showed up relating to oil issues... Including oil cooler in radiator(check coolant reservoir tank and radiator for oil residue)..... Porous thin block(check oil cap,oil,exhaust tips)... I will post more on Tuesday when I get back to work...
"WIDOW" Overkill Edition w/Mace Cams,80mm tb,Jacfab spacer/ported intake,Alky Control,ARH off road pipes,SOLO custom system,3.91 gears, MGW,Phantom grilles,ZL1 appearance pkge, 3dCarbon vents, Lingenfelter hood and spoiler, PLX boost/wideband modules/gauge,ZL1 fuel pump,LF3 hpfp,DSS aluminum driveshaft,JPSS sway bars, Z28 replica wheels and CxRacing coilovers..
09-06-2016, 10:03 AM | #13 |
09-06-2016, 10:04 AM | #14 |
Yeah, I'm pretty sure that I'm out of warranty.
