Old 10-12-2014, 09:05 PM   #1
Oby1
The Force
Oby1's Avatar
Drives: 2013 Camaro 2LT RS
Front Bumper Damage
Anyone know how to fix this? I had an incident with a parking stump and almost ripped my front bumper off.. Any help would be appreciated.
Oby1 is offline   Reply With Quote
Old 10-12-2014, 09:09 PM   #2
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
I'd imagine you'd get a new bumper installed....
[B]
Old 10-12-2014, 09:19 PM   #3
Oby1
The Force
Oby1's Avatar
I'd hate to change the bumper for this.. There has to be some fix.
Old 10-12-2014, 10:15 PM   #4
mySSt
mySSt's Avatar
Drives: '11 SS M6, '14 SS 1LE, '17 SS 1LE
Don't know the exact answer, but unscrew the wheel well liner like you would to remove the front fascia. Look at how that piece was connected and I'd bet you will see a way to re-connect it. Might take a clip or small bolt & nut with washers or some minor fix and nobody will know the difference.
Anyone can drive fast in a straight line, its what you can do thru the curves that matters!
'11 CGM SS M6 ordered in 3/11, '14 BRM SS 1LE from stock in 10/13 & '17 HBM SS 1LE in 11/16 - all from BeckyD!!
mySSt is offline   Reply With Quote
Old 10-15-2014, 11:36 PM   #5
nUcLeArEnVoY
Oldbie that nobody knows
nUcLeArEnVoY's Avatar
Drives: 2011 1SS/RS M6
Sorry to necro this, but that is a very common part that breaks with these cars. Even mine is broken. Just push it back in and tighten the bolt. The bolt will clamp it in place so it won't move anymore, anyway.
nUcLeArEnVoY is offline   Reply With Quote
Old 10-17-2014, 06:41 PM   #6
Oby1
The Force
Oby1's Avatar
I'll try it and see if works. Thanks
Old 10-20-2014, 08:15 PM   #7
Oby1
The Force
Oby1's Avatar
Thanks!! It worked.. Let's see if it holds..
Old 10-21-2014, 10:57 AM   #8
cixinmrigle
Drives: BWM
cixinmrigle is offline   Reply With Quote
