03-06-2017, 02:11 PM | #1 |
Drives: 11 2lt Rs Camaro & 79 383 Corvette Join Date: Apr 2015
2011 Camaro towing?
I brought this topic up before. Last year I wanted to put a tow hitch on my Camaro to carry track tires on a trailer. I just bought a jetski, and this brings up my old discussion of towing with my Camaro. Which one on this site would work best for me? Thank you! https://www.etrailer.com/hitch-2011_...let_Camaro.htm This will not last forever, gonna buy an old pickup when I can.
03-06-2017, 04:29 PM | #2 |
376 cubic inches of fun
Read the owner's manual. "This vehicle was neither designed not intended to be towed with any of its wheels on the ground."
Is that clear? |
03-06-2017, 04:34 PM | #3 |
03-06-2017, 04:41 PM | #4 |
Drives: 2014 2SS RS, 6 sp man Join Date: Feb 2016
I don't think towing something small will hurt it. I don't know how it will do with a lot of tongue weight on the rear. I wouldn't if i could avoid it.
03-06-2017, 04:48 PM | #5 |
03-06-2017, 06:29 PM | #6 |
03-06-2017, 06:44 PM | #7 |
I would go with the Drawtite hitch out of those 2 so that I wouldn't have to drill into the car . Just my 2cents.
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
03-07-2017, 12:51 AM | #8 | |
its in the manual on how much you can tow 9-66 Driving and Operating Trailer Towing (ZL1) The vehicle is neither designed nor intended to tow a trailer. Trailer Towing (Except ZL1) Before pulling a trailer, there are three important considerations that have to do with weight: . The weight of the trailer. . The weight of the trailer tongue. . The total weight on your vehicle's tires. Weight of the Trailer How heavy can a trailer safely be? It should never weigh more than 454 kg (1,000 lbs). But even that can be too heavy. It depends on how the rig is used. For example, speed, altitude, road grades, outside temperature, and how much the vehicle is used to pull a trailer are all important. It can depend on any special equipment on the vehicle, and the amount of tongue weight the vehicle can carry. See “Weight of the Trailer Tongue” later in this section for more information. Maximum trailer weight is calculated assuming only the driver is in the tow vehicle and it has all the required trailering equipment. The weight of additional optional equipment, passengers and cargo in the tow vehicle must be subtracted from the maximum trailer weight. Ask your dealer for our trailering information or advice, or you can write us at our Customer Assistance Offices. See Customer Assistance Offices (U.S. and Canada) on page 13‑5 or Customer Assistance Offices (Mexico) on page 13‑5 for more information. Weight of the Trailer Tongue The tongue load (A) of any trailer is an important weight to measure because it affects the total gross weight of the vehicle. The Gross Vehicle Weight (GVW) includes the curb weight of the vehicle, any cargo carried in it, and the people who will be riding in the vehicle. If there are a lot of options, equipment, passengers or cargo in the vehicle, it will reduce the tongue weight the vehicle can carry, which will also reduce the trailer weight the vehicle can tow. If towing a trailer, the tongue load must be added to the GVW because the vehicle will be carrying that weight, too. See Vehicle Load Limits on page 9‑14 for more information about the vehicle's maximum load capacity. Driving and Operating 9-67 The trailer tongue (A) should weigh 10 to 15 percent of the total loaded trailer weight (B). After loading the trailer, weigh the trailer and then the tongue, separately, to see if the weights are proper. If they aren't, adjustments might be made by moving some items around in the trailer. Total Weight on Your Vehicle's Tires Be sure the vehicle's tires are inflated to the upper limit for cold tires. These numbers can be found on the Tire and Loading Information label. See Vehicle Load Limits on page 9‑14. Make sure not to go over the GVW limit for the vehicle, including the weight of the trailer tongue. Towing Equipment Hitches Use the correct hitch equipment. See your dealer or a hitch dealer for assistance. . The rear bumper on the vehicle is not intended for hitches. Do not attach rental hitches or other bumper-type hitches to it. Use only a frame-mounted hitch that does not attach to the bumper. . Will any holes be made in the body of the vehicle when the trailer hitch is installed? If there are, seal the holes when the hitch is removed. If the holes are not sealed, dirt, water, and deadly carbon monoxide (CO) from the exhaust can get into the vehicle. See Engine Exhaust on page 9‑29.
03-07-2017, 03:00 PM | #9 |
Drives: 2011 2SS/RS 500+ h.p. monster Join Date: Feb 2016
Don't tow with your Camaro Jethro
03-07-2017, 03:15 PM | #10 |
Drives: '17 Corvette Grand Sport M7 Join Date: May 2012
Wait...so, you bought a jet ski, then questioned your towing options afterwards? I grew up with speedboats and if you're privy to watersports, you'd know that you have to back your vehicle into the water pretty far when launching a boat, jet ski, etc.. I'm not certain this is an intelligent choice with a Camaro.
MY RIDE: 2017 CORVETTE GRAND SPORT--TRIPLE BLACK, 7 SPEED MANUAL, VARARAM TCR-7 INTAKE, BORLA CATLESS X-PIPE, CARBON FIBER STAGE 2 AERO, MGW SHORT-THROW SHIFTER
**SOLD**2011 TRIPLE BLACK SS CONVERTIBLE--6 SPEED MANUAL, MANY MODS, 455 RWHP/435 RWTQ DAD'S RIDE: 2012 ZL1 #1866--BLACK, 6 SPEED MANUAL, EXPOSED CF HOOD, POLISHED WHEELS, SUNROOF, ROTO-FAB INTAKE "Silly Americans, taking from the rich and giving to the poor only works in fairy tales. Success is earned here!". |
03-07-2017, 03:24 PM | #11 |
Let's go fishing!
Drives: a car with 8 cylinders Join Date: Apr 2016
"When choosing between two evils, I always like to try the one I’ve never tried before." Mae West 1892-1980
04-06-2018, 10:04 AM | #12 |
Drives: 2010 RY 2SS/RS Join Date: Dec 2007
Old thread but the Camaro is rated for 1000 lbs. I have towed a jet ski and a small motorcycle trailer a several times. The tow rating is limited by the connection point of the hitch on the bottom of the trunk. Obviously the engine, transmission, and brakes are no where near their capacity towing this light load.
Was wondering what is the heaviest anyone has ever towed. Was thinking to buy a small boat and have not yet bought a tow vehicle, wanted to tow the small boat home and not move it again until I've bought a tow vehicle. Probably will end up renting if I can't arrange with a friend to tow.
04-06-2018, 03:51 PM | #13 |
Drives: 2013 Black SS/RS Join Date: May 2017
Dayum. Makes me even more happy to live in Texas.
We have pickups like it was meant to be. |
04-06-2018, 06:49 PM | #14 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
Sure why not? The only advice I might offer is avoid a hitch that sits too close to the ground. On different vehicles once I got a heavier class hitch for added safety than I needed. It's pipe size and construction had it only about 6 inches off the ground, once you added tongue weight it was about 3" of clearance. Going over bumps or rain channels in the road made it scrape. Get one that sits up high enough and a simple wiring kit and enjoy.
