02-13-2014, 03:15 AM | #1 |
Billy The Kid
Drives: Cyber Grey 2SS/RS Join Date: Jun 2009
possible clutch/throwout bearing issue
To those that can give a DIY'er (myself) a hand with knowing for sure how much life is likely left in my clutch, and if my throwout bearing for the slave needs to be replaced or not.
Maybe you could describe a situation or type of noise I would hear on engagement.... Here is what I have concluded so far: currently I notice some feed back to the shifter when quickly operating the clutch pedal while stopped and in neutral along with a less common issue of a catching or a little more than the normally notchy feeling from the shifter while driving normally and shitting around 1800-2500rpm from 1st-2nd or 2nd-3rd etc. *yes I do have the clutch pedal to floor when I feel this in the shifter. Any technical help would be greatly appreciated! Also my current mod list that could have anything to do with this system - mgw shifter - Tick master cylinder - stainless steel braided clutch line - ATE Super Blue dot4 fluid - Separate clutch/ brake reservoirs
CGM 2SS/RS[SIZE="1"]
Performance: LT Headers/Stainless Works cat-back, 225/233 Cam, 1LE 3.91 gears, Custom Tune, BMR suspension, MGW Shifter, Stainless brake & clutch lines, Ideal G Master Cylinder, 275s on all 4 corners Aesthetics: ZL1 Spoiler, DIY LED marker lights, AACPlasma DRL, Yellow Calipers, painted factory wheels |
02-13-2014, 06:27 AM | #2 |
Drives: 2010 camaro SS... shell... Join Date: Nov 2012
How many miles on the clutch? How spirited are those miles? What's the temp like where you are? Have you ever changed the trans fluid? How long ago was brake fluid in clutch reservoir changed? Still the stock clutch? Any performance mods? when you shift are you the kind to slam it into gear as fast as possible or do you ease it in gear? I've also seen that the hurst shifters have a problem with the bushing not sure if this would apply to you as well as far as "feedback".
tried LSXTC...now I'm LSXOD...
02-13-2014, 11:43 AM | #3 | |
Billy The Kid
I've been to the drag strip a few times and have driven on it hard at time but have never had it slip after engagement. I don't shift it super fast as you describe. and if I accelerate under medium or heavy throttle I don't notice it as much, just during the normal everyday puttering around under light throttle. It 'catches' the next gear in any weather, of course the trans and shifting in general is stiffer in anything below 40degree while warming up
02-13-2014, 12:51 PM | #4 |
When my throwout bearing went, it sounded like a grinding metal on metal sound along with a can of rocks being shaken up while the clutch was engaged. It would go away the moment I depressed the clutch.
Vararam Tune CAI, Vararam Power Wedge, 160 degree stat, VMax ported throttle body, Ceramic coated ARH 1 7/8" LTs with X-pipe, Borla S-Type Axle back, MGW short throw, 3.91s, Ported stock IM, BTR Stage IV cam, Heritage Grille, Backup camera, UMI Performance trailing arms and toe rods, dyno tune
02-26-2014, 12:22 AM | #5 |
Billy The Kid
Rabamaro, thank you for the explanation! Much appreciated.
Is there any way to tell for sure on the condition of your clutch? If it was slipping how soon would one be required to change it out? Thanks!
