07-26-2014, 12:58 PM | #1 |
Drives: 2012 Black Join Date: Aug 2012
Res x pipe or mrt v2
Hey guys
I got two options Res x pipe magna flow muffler delete or mrt v2 with no Res x pipe Which one will sound better and meaner Thanks |
07-26-2014, 01:06 PM | #2 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Depends. I've heard good things about both, but the resonated x with straight pipes has no drone supposedly and will arguably sound meaner.
07-26-2014, 01:30 PM | #3 |
07-26-2014, 01:32 PM | #4 |
Its also what I did, so I would say listen to some of the exhaust videos in the LLT tab so that you can figure it out! Lol
07-26-2014, 01:36 PM | #5 |
07-26-2014, 02:12 PM | #6 |
They sound mostly the same, you just need to be able to filter what you hear from the LLTs headers. The LFX will sound more refined and less metallic.
07-26-2014, 02:20 PM | #7 |
Resonated x-pipe WITH the MRT v2 is the most common combination but the resonated x-pipe with muffler delete would be interesting.
07-26-2014, 04:46 PM | #8 |
07-26-2014, 06:22 PM | #9 |
07-26-2014, 06:23 PM | #10 |
07-27-2014, 06:03 AM | #11 |
@dmginc, did you keep your stock resonators? Sounds damn good..
07-27-2014, 10:43 AM | #12 |
yes i did.
07-28-2014, 12:08 PM | #13 |
Drives: RRM RS v6 Join Date: Mar 2014
X pipe -non resonated- with mrt v2 is the balls!!
Magnaflow X - pipe
MRT V2.0 CAI Intake BARTON SS Airlift Suspension V2 Niche Targa 20x10.5 |
Thread Tools | |
