Old 09-09-2015, 09:18 PM   #1
runyonwc
Drives: 2013 ZL1
Where does you clutch pedal start to catch
I just purchased a 2013 ZL1 about two weeks ago and I've noticed the clutch pedal seems to catch kind of high in its travel. Is this normal for ZL1's? In 1st gear leaving a stop light, sometimes I get a little bit of shudder from the clutch but it is not slipping or shuddering in any other gear at WOT.
Is there any way to adjust the clutch or is it fixed since it is hydraulic?
Also, I can hear some whirring or maybe exhaust noise that seems to be coming from behind the gauges in the console under load or firewall. Not sure if this is just exhaust noise or transmission noise. It's not terribly loud but I do hear it. Does this sound familiar to anyone?
Thanks for the help.
runyonwc is offline   Reply With Quote
Old 09-09-2015, 09:37 PM   #2
AGM 1LE
AGM 1LE's Avatar
Drives: 14 SS/ 1LE
The clutch pedal in my 1le catches high in the travel. I believe that is normal for these cars.
2014 1SS/1LE
AGP 57/57s, E85 + meth injection, Monster triple, ZL1 diff swap, Z28 coilovers
AGM 1LE is offline   Reply With Quote
Old 09-09-2015, 10:08 PM   #3
BeachBum
Drives: 2012 (ZL-1) #468
Yes, Clutch Pedal Does Indeed Catch On The High Side - - I Stalled The Car (3) Times Coming Home From The Show Room Floor
BeachBum is offline   Reply With Quote
Old 09-09-2015, 10:33 PM   #4
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
What....do you have dog hearing? lol j/k
Yes, the clutch does catch high...you'll get used to it.
Mods:
Old 09-09-2015, 11:45 PM   #5
dtwolcot2
dtwolcot2's Avatar
Drives: 2012 Camaro ZL1
The shudder comes from hot spots that formed on the flywheel from slipping the clutch too much. I've done it to my last 2 clutches from drag racing trying to get the best times possible. It can go away over time depending on how bad it is and is mostly just annoying. I haven't noticed any negatives from it.
11.633 @ 118.85 Stock M6 Drag Radials
dtwolcot2 is offline   Reply With Quote
Old 09-09-2015, 11:56 PM   #6
hairtrigger
Drives: 69 Chevelle SS396 2013 ZL1
You'll like the high clutch pedal when you find you only have to push it half way down on a no lift shift.
hairtrigger is offline   Reply With Quote
Old 09-10-2015, 07:02 AM   #7
runyonwc
Drives: 2013 ZL1
Thanks for all the replies. The chattering isn't too bad. It is gone if I let the clutch out a little faster. It will just take some getting used to vs my 2002 Z06 I had.
Old 09-10-2015, 07:51 AM   #8
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
High clutch engagement is normal for our cars. Check this out as a way to adjust/lower the engagement height http://ramclutches.com/pedaladjuster.html
camguynj is offline   Reply With Quote
Old 09-10-2015, 08:08 AM   #9
winterboy8
winterboy8's Avatar
Drives: 2015 ZL1 Blue Velvet Metallic
I have the same problem, right from the very beginning and I was original owner. I don't think this car likes you to engage the clutch too slowly, chatters too much. Drives me crazy too, and doesn't always happen either.
Roto-Fab CAI, ARH LT, SW 3" catback, JRE tune, Elite-2 CC, VMAX TB, Big Gulp, WW II relo, Lingenfelter S/C reservoir
winterboy8 is offline   Reply With Quote
Old 09-10-2015, 08:14 AM   #10
lbls1
lbls1's Avatar
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ
I've found that I had to learn the clutch pedal when I got mine. It does kind of catch on the high side, but after awhile you'll learn the pedal and how to minimize the harsh shifting and stalling. The first day with my ZL I must have stalled it at least 5 times (I was a novice at manual shifting), but after some driving and practice I learned the right spots of the clutch pedal and shifts.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic
'15 Malibu LTZ 2LZ Turbo
'14 CAMARO ZL1 Blue Ray Metallic
lbls1 is offline   Reply With Quote
Old 09-10-2015, 08:34 AM   #11
winterboy8
winterboy8's Avatar
I recently reached my break-in milestone and am now able to drive it like I stole it. So I tried taking it to around 6K on the tach and shifting and let's just say my first shift wasn't the best. Not sure if I was surprised at the power or what, but definitely need to get the clutch to gas sync down a little better, or just not fear the NLS and get confident it will always work.
Old 09-11-2015, 12:18 AM   #12
Nickey31
Nickey31's Avatar
Drives: 2012 Nickey ZL1 #001, 2014 Corvette
I have the Ram Clutch pedal adjuster and adjusted it perfectly to my liking. They also make a very nice triple disc clutch now.
Nickey31 is offline   Reply With Quote
Old 09-11-2015, 07:35 PM   #13
camguynj
camguynj's Avatar
Did you install it at the same time as the new clutch ?
Old 09-11-2015, 08:25 PM   #14
runyonwc
Drives: 2013 ZL1
was the install of the clutch adjuster hard?
