08-04-2010, 04:14 PM | #1 |
Summit White 2012 ZL1 M6
Drives: 2010 BLACK 2SS/RS M6 Delvd 8/24/9 Join Date: Jul 2008
AfterMarket X-members
Does anybody know of a company that makes aftermarket cross members for the 2010 SS Camaro. I had the SLP complete exhaust system installed and there is no way to install the cross member without it making contact with the pipes. I need a cross member that will give me clearance of approx. 1/2-3/4 in.
I presently have it off the car and don't want to drive without it. Even though the original member is thin I'm sure it provides some support or they wouldn't have it there. |
08-05-2010, 01:03 AM | #2 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Barton has one as well as a few others. The OEM piece is thin but it's a lateral load so thickness doesn't really mean much.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
08-06-2010, 12:44 PM | #3 |
Drives: 2SS w/ ZZ427 Package!! Join Date: Oct 2008
My suggestion is to loosen the entire exhaust system and then install the cross-piece...
Then go ahead and set a spacer of 1/2 - 3/4 inch on the cross-piece under the pipes... then tighten everything down starting at the front of the car. thsi has happened on tons of cars, and this is the way I fix it here at my shop. Has worked every time!! |
Similar Threads | ||||
Buffalo Camaro5 members | dmo3buffalo | USA - NY / NJ / PA | 1 | 07-09-2010 09:39 AM |
Choko Clothing for USA members. | OUR72GTO | Miscellaneous Items | 179 | 05-24-2010 12:25 AM |
question for any cop members on here | jnewberr2ssrs | Off-topic Discussions | 7 | 03-03-2010 10:30 AM |
Happy Holiday from Hotchkis - Special Discount for Camaro5 Members | Hotchkis | Suspension / Chassis / Brakes | 0 | 12-09-2009 07:33 PM |
Possible Safety Concern with Lowered Vehicles and / or Aftermarket Wheels | JusticePete | Suspension / Brakes / Chassis | 1 | 12-04-2009 11:20 AM |
