Old 10-15-2015, 08:56 PM   #1
kinpin
618 RWHP
kinpin's Avatar
Drives: 2014 ZL1
Line lock for a ZL1.... help please
I would like to put in a line lock for my 2014 ZL1 .. Which one works best ?
and how do you stop the computer from going nuts and setting off codes for the stability track system ?
kinpin is offline   Reply With Quote
Old 10-15-2015, 09:00 PM   #2
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
I have the hurst kit, never had any issues with it.
http://www.summitracing.com/parts/hu...t/model/camaro
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - Stock
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 10-16-2015, 07:33 AM   #3
2013 ZL1 #7860
Drives: 2013 ZL1 A6 #7860
Pull the ABS fuses
2013 ZL1 #7860 is offline   Reply With Quote
Old 10-16-2015, 08:05 AM   #4
14ZL1M6
14ZL1M6's Avatar
Drives: 2015 ZL1 Coupe A6 & 2002 ZO6
There are 2 kits that I know of....Hurst and SLP. They are both going to work about the same. Aesthetically speaking, I like the Hurst because the solenoid has its own bracket that mounts to the brake booster. The SLP solenoid has to be mounted to the fender well, which means drilling holes. I'm not a big fan of drilling holes in my $60k car!! Haha
2015 ZL1 A6 Coupe Crystal Red
ATI Balancer w/9.55 (22.5%) lower pulley, FIC1000 Injectors, Stainless Works 2" headers, Stainless Works Retro Cat-Back, V-Max Ported TB, Roto-Fab w/Big Gulp, Elite 2nd Gen Catch Can, Jannetty Tuned. 581 rwhp
14ZL1M6 is offline   Reply With Quote
Old 10-16-2015, 11:59 AM   #5
FA5TRNU
Drives: 2013 Camaro ZL1 Victory Red A6
Which fuses are the ABS fuses?
FA5TRNU is offline   Reply With Quote
Old 10-16-2015, 04:23 PM   #6
ZL1Kid_AL
ZL1Kid_AL's Avatar
Drives: 2014 ZL1- Summit White M6
Pull the fuses if you are worried about the codes coming up.
Although when I use my Linelock the codes don't get thrown unless it is an excessively long burnout like 10-15secs. Even then it does nothing to alter performance and just turns all the nannies off and shows the "service stabilitrak" icon on the dash.. I make my pass go to the pits and when I turn the car on again everything is back to normal. Hurst is the best unit IMO
750whp @ 13psi Garage Built on Jack Stands.. 850++ 100 shot of sauce
ZL1Kid_AL is offline   Reply With Quote
Old 10-17-2015, 09:08 PM   #7
kinpin
618 RWHP
kinpin's Avatar
Drives: 2014 ZL1
tank you all ... I am going to get the Hurst
Old 10-18-2015, 08:43 AM   #8
2013 ZL1 #7860
The ones labelled ABS in the engine compartment fuse box...
I pull both, don't remember what numbers they are.
Old 10-18-2015, 04:37 PM   #9
dtwolcot2
dtwolcot2's Avatar
Drives: 2012 Camaro ZL1
I do the same. 40 & 43. One is a mini fuse and the other I think is called a j case??? It's square and clear on top. With the fuses pulled it also eliminates having to turn everything off.
11.633 @ 118.85 Stock M6 Drag Radials
dtwolcot2 is offline   Reply With Quote
Old 10-18-2015, 06:10 PM   #10
Cooks ZL1
Drives: 13 Camaro ZL1
I'd also recommend a Switchlink. It's a module that your wire into the car that allows you to use the cruise control cancel button on steering wheel as the button for line lock. The switch that comes with the hurst kit is pretty cheesy and this will make it stealth. I have it and love it. Also am using the hurst line lock.
Cooks ZL1 is offline   Reply With Quote
Old 10-18-2015, 06:36 PM   #11
UF4LIFE102SS
Treasure Coast Camaro 5
UF4LIFE102SS's Avatar
Drives: 2010 2 SS
Yeah I use the cc button. SJM not around any more?
Old 10-18-2015, 07:09 PM   #12
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
What is a switch link ?
Crash76 is offline   Reply With Quote
Old 10-18-2015, 07:16 PM   #13
nighttowl
nighttowl's Avatar
Im not sure if switch-link is still in business, their websites are shut down.
Old 10-18-2015, 07:57 PM   #14
Chad's ZL1
THERAPY
Chad's ZL1's Avatar
Drives: Red Rock Metallic ZL1
This works with a stick shift as well?
Chad's ZL1 is offline   Reply With Quote
