Old 08-18-2016, 09:33 AM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Question Proper bearing install??
So what picture is correct for main and rod bearings?
I've seen it both ways.
What picture is correct top or bottom?
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 08-18-2016, 09:50 AM   #2
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Sub'ed, but I believe the offset (bottom photo) is correct.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 08-18-2016, 10:35 AM   #3
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
I've never seen it done the bottom way and never had. This is the way I was taught and it's work 100% of the time every time.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 08-18-2016, 11:46 AM   #4
JerTM
JerTM's Avatar
Drives: 2011 2SS/RS M6
Direct from GM's Service Information for a 2014 6.2L
"Install new upper connecting rod bearings into position. Roll the connecting rod bearings into position so that the lock tang engages the alignment slot. The connecting rod bearings must fit flush in the connecting rod . "
So I would say the first picture is the correct way.
JerTM is offline   Reply With Quote
Old 08-18-2016, 04:01 PM   #5
2010_camaro
Bottom picture is how the engine was taken apart
Old 08-18-2016, 04:14 PM   #6
CFD
Drives: 2SS/RS L99 BLACK
The bearings should sit flush as in the first photo, chances are the bearing moved during disassembly.
CFD is offline   Reply With Quote
Old 08-19-2016, 10:00 AM   #7
2010_camaro
All rod bearings was like the bottom picture. The mains where flat across.
Old 08-19-2016, 10:33 AM   #8
JerTM
JerTM's Avatar
From the factory? That would be a first for me, I've taken down a few LS engines to replace pistons and rings under warranty, never saw a bearing installed that way.
