Old 10-07-2016, 11:07 AM   #1
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
What RPM are you guys turning?
I have a 2015 1LE with 1.85 rockers, PSI1511 Springs and Titanium Retainers along with 1 7/8 ARH 3" x pipe, Z28 CAI and home ported intake with rod mod and self tuned. I just bumped the limiter up to 7300 to go through the traps next time in 3rd gear. I trapped 115 shifting to 4th I had my limiter set at 7000 and it would only trap high 112 in third. my best pass on stock tires was 12.52 @ 115.24 MPH
lazerlemonta is offline   Reply With Quote
Old 10-07-2016, 11:08 AM   #2
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
Aftermarket cam? The stock cam falls off at that high rpm.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 10-07-2016, 11:11 AM   #3
lazerlemonta
Drives: 2010 C6 1LT
You want to pull a gear keeping you in the most optimal power band. I shift 1st and 2nd at 68-6900 and will ride third out to 7300.
Old 10-07-2016, 11:14 AM   #4
Russell James
Russell James's Avatar
7300 is way too high for a stock LS3. If you've upgraded the valve springs 6700/6800 max. Stock cam... no reason to go above 6600.
To build a motor that can reliably spin higher than 7000... it will have some really nice pistons/rods/rod bolts/shaft mount rockers... high dollar stuff.
Spinning a stock bottom end LS3 over 7000... one day the pins will rip right out of the pistons. Seen it happen. And seen engineers comment... oh yeah, can't do that with those pistons.
Reset limiter to 6600, shift to 4th in the qtr.
Nobody ever takes that advice, so good luck.
Old 10-07-2016, 11:19 AM   #5
Russell James
Only problem there is...you don't have a 7300 rpm capable motor.
Have it pro tuned. Self tuning is a recipe for disaster...especially if you think it can spin 7300.
Pro build a $30 - 40K race motor... then spin it to the moon.
Old 10-07-2016, 11:47 AM   #6
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
I don't drag race but I would never go to 7300.
zz430camaro is offline   Reply With Quote
Old 10-07-2016, 12:19 PM   #7
Unreal
Drives: 2006 Z06
7500rpm, self tuned.
Only 24k miles like that, and 100+ 1/2 mile passes and 1000+ street pulls.
Nick
Corvette Z06 -1200ish rwhp
Old 10-07-2016, 12:27 PM   #8
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Titanium keepers and retainers are well suited to a race motor. Race motors are routinely inspected or torn down completely after a race. They change out the titanium keepers and retainers to ovoid failure, before they fatigue and crack.
In a street / track motor, use Tool Steel keepers and retainers for greater reliability.
The plastic trays in your stock motor are not designed to keep the lifters correctly oriented to the cam at RPMs in the 7k range. Be happy you have not incurred a failure and dial that baby down or tear it down to install link bar style lifters and toss the plastic trays, shaft mounted rockers and more.
Old 10-07-2016, 12:39 PM   #9
Bo White
Bo White's Avatar
Many of the top drag guys shift 7000+
Got to have the valvetrain to support it.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 10-07-2016, 12:59 PM   #10
lazerlemonta
Drives: 2010 C6 1LT
Thanks guys for all your input.
Old 10-07-2016, 01:00 PM   #11
JusticePete
Exactly, they don't run 7k+ on stock engines.
Old 10-07-2016, 01:09 PM   #12
Unreal
Drives: 2006 Z06
The plastic trays in your stock motor are not designed to keep the lifters correctly oriented to the cam at RPMs in the 7k range. Be happy you have not incurred a failure and dial that baby down or tear it down to install link bar style lifters and toss the plastic trays.
Disagree on the plastic tray. Ls7s rev factory to 7k+ and run plastic trays. I know atleast 50 cammed ls7 cars with zero issues on stock plastic trays. The trays are not an issue. Valve control is far before plastic trays.
My car runs amazing, so not going to tear it down to fix a non-issue.
Nick
Old 10-07-2016, 01:36 PM   #13
JusticePete
I am happy to hear it is running well.
You won't find a single full race motor running with plastic trays. The plastic trays are an inexpensive way to build a production motor. Search the forum and look for cam failures. Count how many are directly related to a turned lifter. Some are poor installation, some are cracked trays, some are over-revved, but if it is your motor, it is one too many and very expensive.
As for the LS7, they are a really nice limited production motor, that still has weak points.
To put this in perspective, a Chevy non-current SB2 NASCAR motor have an $18,000 billet steel crank. The pushrods are as big as thick as some cigars. New they were over $120K. All this to be able to run one 500 mile race. In that light, what we get out of a LS3 or an LS7 is the bargain of the century.
We keep them a bargain by not breaking with up graded components. Link bar lifters, shaft mounted rockers and helicoils for the stands.
Old 10-07-2016, 03:13 PM   #14
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
What size tire? It may be worth it to add some tire height if you're trying to finish in third gear. I'm having the same line of thought after my last track outing and having to go to fourth just before the beams. I'm contemplating a 295/40/20 for the rear instead of the 275/40/20 there now. That half inch in tire height is 2.2%, 2.5mph more in 3rd - should get me to 115-ish without 4th gear (fuel cut is around 112-113 right now @6600rpm).
I realize 3rd is a touch shorter in the MM6/3.91 setup - a 315/40/20 would get you there in third at a reasonable 6600rpm @ 115mph.
I'm with these guys, 7300, even 7000, is too much. I'll stay with the factory 6600 for my fuel cut - I certainly understand the value of running third out, but it's not worth the risk. If I can't get there on tire size then I'll keep on shifting or running her out on the limiter, at 6600pm.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
