05-05-2011, 10:58 PM | #1 |
Camaro SS Lover
Drives: 2010 Camaro 2SS/RS Black IOM Join Date: Jun 2010
BlueTooth, Blackberry and Audio (music not phone)
Wondering if anyone has been successfull at getting their BlackBerry to stream audio to the vehicle stereo via BlueTooth?
I've paired the BlackBerry to the vehicle, phone works great but when I use an app. to stream music it won't work. ie - Slacker Radio. Anyone get this to work successfully or aware of a C5 thread that already explains how to accomplish this?
2010 Camaro SS, P1SC SuperCharged Livernois LSX429ci., 1 7/8" LT Headers, full 3" MBRP exhaust, SPI built/tuned, a total
05-06-2011, 11:16 AM | #2 |
Voice Of The Voiceless
You will need to sync your phone with the Audio Bluetooth via the stereo.
05-11-2011, 10:22 PM | #3 |
Drives: 2011 Camaro 2LT RS, Red Jewel Join Date: Apr 2011
After spending 2hrs today trying to pair my droid to the stereo so I could stream music and directions (via google maps) to it, I contacted a GM rep via Onstar today to ask how to stream the audio via bluetooth. Per the rep, the Camaro will only support telephone voice via bluetooth. It will not allow the phone to stream any other audio source via bluetooth. It's really too bad that the 2LT has only the USB jack in the centre console and not the 3.5mm jack. I could probably stream the audio that way if I did; but per the dealer, only the 1LS, 1LT, and 1SS have the 3.5mm audio jack.
Still not quite done.
05-11-2011, 10:34 PM | #4 | |
Camaro SS Lover
05-11-2011, 10:39 PM | #5 | |
Perhaps I can get something like this: http://www.newegg.com/Product/Produc...-020-_-Product to stream the audio from my phone / MP3 player.
05-11-2011, 11:30 PM | #6 |
Custom User Title :D
Drives: 2011 Summit White 2LT/RS Join Date: Dec 2009
Angelsilhouette-
lol you got some bad info... first- if you have the USB port, you have a 3.5mm jack, too. it's on the same plate in the center console... its directly below the USB port. second, the OnStar rep is WRONG WRONG WRONG When I had a Blackberry, the blackberry didnt like to be paired for handsfree phone and music streaming at the sam time, but it was the fault of the phone. I have an android phone now, and it streams music over bluetooth fine. Select your Aux jack input, then press menu/select, go into bluetooth setup, and add device. you will walk through pairing the bluetooth audio device. you will have to select aux jack, then push menu/select and select your bluetooth device every time you want to use the bluetooth audio (not re-pair, just pick the bluetooth device) ....it's covered in the manual |
05-12-2011, 08:06 AM | #7 |
I haven't taken the opportunity to study my manual back to front, yet.
I just ran out to my car to check for the 3.5mm jack and... quite embarrassingly... It pointed at me and laughed. >.<
05-12-2011, 10:55 AM | #8 | |
Camaro SS Lover
05-12-2011, 11:02 AM | #9 |
Drives: 2010 Camaro 2SS Join Date: Aug 2009
I'm not streaming but I do have my BB set up to play stored mp3s via Bluetooth, works perfectly!
05-12-2011, 02:23 PM | #10 |
Defending the Nation...
Drives: '16 Summit White 2SS, A8, Sunroof Join Date: Dec 2009
OP,
You CAN be connected to the car via bluetooth for both phone calls AND music streaming. It is two separate bluetooth pairings. The standard phone is one and it sounds like you already have that setup. The second one is called GM Music Connect. You have to navigate through the menus on your radio to initiate it then you have to search with your phone for the signal the car radio is putting out. Once you are paired with GM Music Connect, you can stream audio. It's hit and miss but when you get in the car, it should connect to both. Sometimes I have to go into my Blackberry's "signals menu" and go to Blackberry Options and click GM Music Connect to get them both up but once done, stream away! Hope this helps!
'16 2SS, A8, Sunroof, non-NPP "SURSUM AB ORDINE" |
05-12-2011, 08:02 PM | #11 |
Welp... Got out of work and in less than a minute, I had the phone streaming slacker radio to my car stereo. It was very nice, but the phone kept losing the slacker signal and the car radio would then switch itself to the CD input.
05-12-2011, 09:22 PM | #12 |
was it actually only loosing the slacker/data signal, or was the bluetooth dropping? watch the bluetooth icon on the radio and see if it disapears
05-12-2011, 09:24 PM | #13 |
Bluetooth is fine, normally; I've never dropped a call, yet. (Though I do try to keep calls short while I'm driving.)
05-13-2011, 04:29 PM | #14 | |
Drives: 2SS RS Join Date: Jul 2009
this needs to be "sticky'd" !!! been trying to remember how i got my BB to do both phone and music via BT for over a month ever since i got my new drioid phone...... the Dealer was clueless, the 800-ppl were clueless... just glad i decided to give our forums another go through!!! Droid now doing phone, music and nav all @ same time and all flawlessly!!! THANKS!!!!! |
