05-12-2015, 08:18 PM | #1 |
Drives: 2015 1LE Join Date: May 2015
What pumps come in the 15 1LE?
What fuel pumps come in a 15 1LE, looking to make 700 rwhp with meth and 95lb injectors. Do I need a BAP, ADM ZL1 FPM or both?
TIA! |
05-12-2015, 08:31 PM | #2 |
Drives: 2010 ss/rs Join Date: Jun 2013
the livernois pump will be plenty ,and does not require a module change.
rotofab cai
ported throttle body sp headers with cats loud mouth axle back no mufflers tuned by steve williams 6l80etuning.com bmr split springs cam motion custom camshaft btr 660 spring kit maggie 2300 id850 injectors livernois fuel pump |
05-12-2015, 08:55 PM | #3 |
Drives: All things Turbocharged Join Date: Dec 2010
Stock pump is same as ZL1 in that car, but the FPCM is not the voltage amp type like a ZL1, so you will want a MSD voltage booster at least. With that set-up we are getting 750whp on completely stock 1LE's with our kit. (up to 806whp on race gas, 100% stock car)
05-12-2015, 09:57 PM | #4 |
Drives: 15' SS Join Date: Nov 2013
Thanks for that info. Might have to go that route
05-13-2015, 07:32 AM | #5 |
Thanks AGP!
05-13-2015, 05:24 PM | #6 |
Drives: C7 Z51 Join Date: Mar 2014
LE cars have ZL1 pumps. you can take the car to a dealer or someone with Tech-2 and they can reprogram the voltage to run ZL1 pump at full capacity. no need for additional parts.
05-13-2015, 05:32 PM | #7 |
Lets roll...
Drives: 14' Join Date: Jun 2014
Oh snap! When would you say the 1LE would start running out of pump before and after the reprograming?
05-13-2015, 06:01 PM | #8 |
with control module about 700rwhp. with BAP and FPCM about 800rwhp
05-13-2015, 06:07 PM | #9 | |
Lets roll...
What about with the car (1LE) untouched? How much power will the pump support?
05-14-2015, 08:29 AM | #10 |
~550ish untouched, but that depends on power adder/etc. NA, Turbo, PD, N2o, etc. Turbos and NA can get farther than blowers.
Nick
Corvette Z06 -1200ish rwhp |
07-22-2015, 06:26 PM | #11 |
Can this be done with HPT? Can you transfer all the settings over from a ZL1 on the fuel system tab?
07-22-2015, 06:56 PM | #12 |
Too much is never enough!
Unfortunately not.
07-24-2015, 08:52 AM | #13 |
07-24-2015, 09:35 AM | #14 |
Because HP tuners can't program or access the FPCM. Need a tech 2 to do that.
Nick
Thread Tools | |
