09-30-2017, 05:35 PM | #1 |
Drives: 15 Z28, 01 Corvette, 96 Corvette Join Date: Dec 2016
Need help, left race track and ever light on car is on
Left an HPDE and every light came on.
Service power steering Service abs Sercice traction control Brakes worn What the heck? No way all that stuff just broke at once.
2018 Sierra RCSB | 2015 Z28 Camaro | 1989 B2200 with a 327 | 1996 LT4 Z51 Corvette | 1973 427 Nova
09-30-2017, 06:03 PM | #2 |
Drives: 2015 Z28 #980 Join Date: Jul 2016
Drove the shit outta it! Haha
Hope all is fine. Did you try to pull any codes? |
09-30-2017, 06:18 PM | #3 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Any CEL? Any other drivability issues after the dash lights came on? Could be something as simple as a low voltage issue. Need some more info...
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
09-30-2017, 06:24 PM | #4 |
Drives: 2015 Z/28 Join Date: Jun 2011
Brakes worn means that the brake pads are worn to the point of the sensor, roughly down to the 2-3mm point, or it could be a loose sensor. With the others all coming on, more likely than not you have had something come unplugged, in my case it was a spark plug wire. If you have the car running, and hear a loud ticking, that's probably it. That triggered the service stabilitrac, not sure if it triggered the others. A friend of mine had the issue from a cam position sensor coming unplugged. more likely than not, nothing damaged, good luck with the hunt. Let us know what you find
09-30-2017, 06:32 PM | #5 |
I know the pads issue. All are fine. On sensor broke to soon.
Voltage is 14.8
09-30-2017, 06:33 PM | #6 |
CEL? No errror codes. Checked with a cheap code reader. Trying to find a tech two
09-30-2017, 06:34 PM | #7 |
Talked to service writer at GM he says to find a tech 2 and clear the history fault codes. Anyway to do that without one? Unhook battery? Pull fuse?
09-30-2017, 06:37 PM | #8 |
Drives: 2012 BMW 135i Join Date: Nov 2016
Did you boil your brake fluid? On a none Chevy car a friend of mine had his abs module spaz out and led to issues which required some special tool iirc.
If everything appears mechanically ok with the car maybe pop the neg bat terminal and let the car sit for a few min and reconnect? |
09-30-2017, 06:51 PM | #9 |
No, i run moteg 660
09-30-2017, 07:09 PM | #10 |
Drives: 2015 Z/28, 2007 HHR Join Date: Jan 2014
If you have that many lights, your scanner didnt ping all the modules. Try to get a scan that will address the pcm, bcm, abs module, tcm..etc. even if you have disconnected the battery already, a permanent dtc will still store. Then maybe I can help your further.
09-30-2017, 07:14 PM | #11 |
I cleared mine by unhooking the battery between sessions, roughly 90 minutes.
09-30-2017, 07:20 PM | #12 |
Battery is currently unhooked. I checked all the fuses. I get the tractional control notice as soon as i turn key on.
09-30-2017, 07:26 PM | #13 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
Look to see if one of your plug wires is off a spark plug.
09-30-2017, 08:05 PM | #14 |
Plug wires are fine
