Old 03-26-2013, 05:27 PM   #1
carrs_crew
Livin the Dream
carrs_crew's Avatar
Drives: sold
Which install kit for 3.91 GM gear install
Which kit did you use to install your GM 3.91 gears? Best place to get each?
thanks
Chad
carrs_crew is offline   Reply With Quote
Old 03-26-2013, 05:35 PM   #2
96MrBass
96MrBass's Avatar
Drives: GM
Lingenfelter kit has everthing you need I think it was around 200 bucks.
Roto- Fab Cai, SLP 1 3/4" headers, 3"X pipe, LM2 cat back, Comp Cam & AI Heads, SLP UP, RPM Tuned, GPI Intake, Vmax TB, ADM Air Scoop, 3.91 Gears, Gforce driveshaft, Braille 21#, Elite Catch Can, Pfadt Tie Rods, Diff Bushings and Trailing arms, Eibach spings & sways, BMR cradle bushings, Nt555r's.
96MrBass is offline   Reply With Quote
Old 03-26-2013, 06:42 PM   #3
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
This is the Kit we offer with our gear sets. Part # L380041410 for reference. Please feel free to call, PM or email me anytime with questions.
Best regards,
Tyler
888-308-6007
Old 03-27-2013, 09:16 AM   #4
carrs_crew
Livin the Dream
carrs_crew's Avatar
Drives: sold
thanks for the replies, I will be going that route.
Old 03-27-2013, 10:00 AM   #5
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
Personally, I think the Lingenfelter Kit is over-kill. It duplicates all the hardware that comes with the gears (i.e. ring gear bolts, crush sleeve, and pinion nut come with the gears and the kit). Don't get me wrong, it is a very thorough kit, and includes both Pinion Gear Bearings, but no bearing races. I used the LPE kit when my 3.91's were installed. My installer did not understand why pinion gear bearings would be changed without replacing the races too (makes sense to me). They wanted it done right, so they ordered the pinion bearings (w/ races) from the dealership. I also ordered the (2) carrier bearings (w/ races) from the dealership too. In the end, they used one set of pinion shims from the kit, and re-used the stock carrier spacers. I ended up with about 20 lbs. of unused shims and spacers!!! My installer cut a little bit off the cost of the labor and asked if he could keep the remaining shims, spacers, bearings. Worked out good for both of us, but if I had it to do over again, I would probably just use this "half-kit" instead, and order my bearings (w/ races) through the dealership. Cheaper in the long-run. Just my .02 cents!!!
http://www.ringpinion.com/b2c/Produc...rce=DiffWizard
blazzin1 is offline   Reply With Quote
