04-01-2013, 01:46 PM | #1 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
3.91 break in procedure, 2 1/2 hr drive home from shop
I'm ready to have the GM 3.91's installed and I know there has been some threads here regarding break in procedure. My question is, if I have a shop do the swap but they're a 2 1/2 hour drive back home, is it ok to drive that long right after a gear swap. I understand that it is recommended to drive for a half hour or so then let it cool, then another half hour and so on. So what do I do if I have a 2 1/2 hour drive? Maybe drive 45 minute segments? It'll be a LONG drive home! Any advise is welcomed!
04-01-2013, 01:48 PM | #2 |
Are you getting just the gears put in or an entire rear-end built by GM. If just the gears then yes I would allow for some cool down. If complete rear-end breakin would be like when you got the car new.
04-01-2013, 01:53 PM | #3 |
BL1ZZRD
Just the gears. Swapping stock 3.42's with GM 3.91's, nothing else.
04-01-2013, 02:11 PM | #4 |
Drive maybe half way and stop and get something to eat, vary speeds not driving at the same speed all the time.
My entire rear-end is being put in as we speak. |
04-01-2013, 02:14 PM | #5 |
BL1ZZRD
04-01-2013, 02:46 PM | #6 |
You can still do the heat cycles (as recommended). Just drive for 20 min. or so, and then pull over and stop for 10-15 min. Do that about 3 times and you're done. Makes for a "looooong" ride home, but by the time you get home, your gears will be properly heat cycles and ready for some real action. I've also heard to "take it easy" for about the first 500 miles or so....not sure how necessary that is???
04-01-2013, 03:05 PM | #7 |
04-01-2013, 03:26 PM | #8 |
Drives: Silver 2010 SS Camaro Join Date: Jul 2009
I'm in the process of breaking in my Gforce 9 inch with 3.90 gears and it states to drive the car under light load for 50 miles and then let it cool down (this will take longer than 15 minutes) and then do it again. Next take it out under medium load the same way as before twice. By now you should have about 200 miles on it and you can do normal driving for another 200 miles, no wot pulls. After that you are good to go!!!
MODS:
ADM built 417, 2.9L Whipple with 3.250 pulley, ADM ported and polished LSA heads,ADM stage3 cam,ADM LSA belt drive system,ADM CAI race scoop, ADM dual fuel pumps, ID 850's, BMR full suspension, Gforce 9 inch kit with 3.5 inch driveshaft, Street Slayer twin carbon clutch, Lingenfelter oil seperator. Tuned by built by ADM Performance, 763rwhp,705rwtq |
04-01-2013, 04:19 PM | #9 | |
Drives: 2SS/RS Join Date: Sep 2008
The cool down cycles take hours, not minutes. Remember the gears get really hot and so does the fluid. Hot metal surrounded by hot fluid takes a long time to cool down. I've done a couple rear end fluid changes a couple hours after a car has been driven for 30-45 minutes and the fluid still be hot enough to burn my hand. If you follow the directions, it will take you all day to not even cover half the distance. |
04-01-2013, 06:49 PM | #10 |
BL1ZZRD
This is why I'm concerned! I want to make sure I don't overheat them and cause whine and short life. The shop owner says that it won't be a problem so that's why I'm throwing this concern out there! I'll wait for more opinions!
04-01-2013, 06:52 PM | #11 | |
BL1ZZRD
04-01-2013, 07:07 PM | #12 |
Going through the heat cycles is very important for longevity and so it doesn't whine.
MODS:
04-01-2013, 07:35 PM | #13 |
Stroked and blown
20 to 30 minute intervals. Change the diff fluid at 500 miles, than bombs away. Avoid hard shifting for first 500 miles
Failure to follow this can result in gear whine, permenantly
04-01-2013, 08:38 PM | #14 |
Drives: 2SS/RS CGM LS3 Join Date: Aug 2009
JRE installed my 3.91's. I live about 1 hr 45 min away. Ted had his son take my car out for the first 20-25 minute run, then we let them cool down. He then told me to take it easy for a couple hundered miles, then I should be good. He said change the diff oil at about 1000 miles.. Mine are very quiet BTW...
