Old 01-08-2013, 09:27 AM   #1
Betiwin
Drives: CTS-V Coupe and GT500
LSA Mod Help.
Those that have done 2.55 Pulley, Ported snout, and intake:
What was you injector duty cycle?
Did you add injectors for above Mods?
If so which one?
Who tuned you car.
Getting ready to do this and not sure if I need injectors.
Thanks.
Betiwin is offline   Reply With Quote
Old 01-08-2013, 11:04 AM   #2
Jeff65SS
Jeff65SS's Avatar
Drives: 1965 Chevelle Malibu SS
I did the Lingenfelter 630 package on my car, which consists of the modifications you mentioned. Not sure what the duty cycle of the injectors were, but I did not have to replace the stock injectors for those mods. Tuned by MTI Racing in Marietta, GA.
Jeff65SS is offline   Reply With Quote
Old 01-08-2013, 12:51 PM   #3
69NMYSS
69NMYSS's Avatar
Drives: '69 Camaro SS and '12 ZL1
you will likely be around +95% DC. Anymore more power upgrades and you will need injectors
69NMYSS is offline   Reply With Quote
Old 01-08-2013, 01:26 PM   #4
The Baron
The Baron's Avatar
Drives: 2013 zl1
On a cts v you DO NOT need injectors with those mods. I have a 2.38 and stock injectors
The Baron is offline   Reply With Quote
Old 01-08-2013, 01:53 PM   #5
RoketRdr
RoketRdr's Avatar
Drives: 2010 Duramax; 2012 CTS-V Coupe
Here's a nice calc that will help you pick the right injectors for the expected power level.
http://www.rceng.com/technical.aspx
RoketRdr is offline   Reply With Quote
Old 01-08-2013, 04:24 PM   #6
Betiwin
What's ur IDC with 2.38? What's ur RWHP and TRQ if u don't mind sharing?
Old 01-08-2013, 04:26 PM   #7
Betiwin
69SS was at a dealer picking up 3 new fleet vehicles today. Your exact color combo was on floor. Wow I must admit it was stunning. White and black looks good in pictures but in person is a knockout. (This is coming from a GT500 owner too! Wife's car is the V). I was impressed to say the least.
Old 01-08-2013, 05:07 PM   #8
Mattzl1
Mattzl1's Avatar
Drives: 2013 ZL1
If so which one?
Who tuned you car.
Thanks.
I am getting those same mods done and adding a cam also and will need bigger injectors. I am going with the ID850's
2013 ZL1 AGM, ECF, A6, sunroof, black rims
mods complete! 664 RWHP, 645 RWTQ
Ported snout, 2.5 upper, Innovators west balancer with 9.1 lower, New era intake, American Racing long tube headers with hollow cats and X pipe, KDI heat exchanger, ID850's, TS29 cam !
Mattzl1 is offline   Reply With Quote
Old 01-08-2013, 08:00 PM   #9
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
Stock engine will hit 93% duty cycle. I know I am over 100% now. How many of you know that you can up the fuel pressure in the tune. And you will effectively have larger injectors. The ZR1 has same injectors as ZL1 but programmed to run at higher pressure.
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 01-08-2013, 08:13 PM   #10
The Baron
The Baron's Avatar
Drives: 2013 zl1
car has ls9 cam, cold air and 2.38 pulley, no ported blower or anything else..... made 577 on a mustang dyno and has went 11.40s at 126 at a 4450 race weight.. gets driven very day by my wife... has 45,000 miles on it now..stock injectors... auto car..
they are maxed out right now.. but the car runs like a stripped ass ape..
i keep reading about these zl cars being maxed out from the factory or in the 90% range... i dont believe it, but it is what it is..
my zl has id 850s in it, but I did 2.38, headers, fully ported blower and cold air.. I am doing a cam in a few weeks. without the cam he id850s are at 78% on my zl right now..
Old 01-08-2013, 09:11 PM   #11
ZO6 Bryan
ZO6 Bryan's Avatar
Same injectors get cranked to 87 psi in a ZR1 under high load conditions compared to only 65 psi in a ZL1. This is easily changed in HPTuners.
Bryan 2018 ZL1 M6
Old 01-08-2013, 09:55 PM   #12
Betiwin
This is also what I was told. Stock in injectors just need more pressure from pump. Anyone know how bad this is for stock pump?
Old 01-09-2013, 12:08 AM   #13
EVLZL1
EVLZL1's Avatar
Drives: '13 Black ZL1,MN6,Suede pkg,
I'm leaning towards the ID850's as well, big $$ though.
EVLZL1 is offline   Reply With Quote
Old 01-09-2013, 12:23 AM   #14
Flavorwrench
Flavorwrench's Avatar
Drives: 2012 ZL1 & 67 RS-SS TwinTurbo
Anyone want to share where to find the lowest price on ID850's.
Flavorwrench is offline   Reply With Quote
