HURST
Old 05-28-2010, 04:52 PM   #1
FutureCamaroOwner
FutureCamaroOwner's Avatar
Drives: White 1SS/Black Stripes
How much to change V8 front fascia to V6?
Does anyone know. I want to replace te SS with the V6 fascia.
FutureCamaroOwner is offline   Reply With Quote
Old 05-28-2010, 04:58 PM   #2
daphatgrant
June '10
daphatgrant's Avatar
Drives: '10 2SS/RS RJT
The SS front fascia is $265 from Dave Hiller at Newman Chevrolet (where CamaroScotty works) so I'd assume that the V6 is about the same. You can contact Dave @ dhiller@north2newman.com.
RJT, 2SS/RS, M6, Black Int, Sunroof.
daphatgrant is offline   Reply With Quote
Old 05-28-2010, 05:01 PM   #3
sprtplt
sprtplt's Avatar
Drives: Corvette
I see the fascia pretty reasonable on Ebay. painting and swapping if you know a good shop would not be bad. Under $500 (good guess) from a shop I use
sprtplt is offline   Reply With Quote
Old 05-28-2010, 05:13 PM   #4
KMPrenger
KMPrenger's Avatar
I would try hard, hitting up the V6 members on this site to see if any of them want to do a swap with you. I'd say you have a good chance of finding a taker.....maybe you'll get really lucky and find a summit white V6 car!
Old 05-28-2010, 05:13 PM   #5
Number 3
Hail to the King baby!
Number 3's Avatar
Drives: '16 ATS 2.0T & '17 Buick LaCrose
Double check how hard you drive your car. There is a reson why the lower grill opening is larger on the V8 front fascia. If you go to a V6 you will have less airflow. Just a caution.
"Speed, it seems to me, provides the one genuinely modern pleasure." - Aldous Huxley Link to Every Camaro photo I've taken in Hi-Resolution
Old 05-28-2010, 05:59 PM   #6
BlessedChef10
BLESSEDCHEF10
BlessedChef10's Avatar
Drives: 2010 2lt camaro rs
Ill trade you for mine! Its black
BlessedChef10 is offline   Reply With Quote
Old 05-28-2010, 05:59 PM   #7
FutureCamaroOwner
I am going to be getting a carbon fiber hood with ram air and heat extraction. I don't like the look of two scoops
Old 05-28-2010, 06:02 PM   #8
Maurdib
Maurdib's Avatar
Drives: 2010 Black Camaro 2LT/RS Auto
I'm going to get that same hood, any ideas on it's weight?
BackInBlack
Performance:Vararam cold air intake
Maurdib is offline   Reply With Quote
Old 05-28-2010, 06:39 PM   #9
djsnoflake
Faith Keeper
djsnoflake's Avatar
You could always just get the mailslot filled. But that might end up being more expensive than just buying a new bumper.
Also like the idea of proposing a swap with a forum member. I imagine some of the V6ers would like a mailslot
Old 05-28-2010, 08:54 PM   #10
LosingReality
LosingReality's Avatar
Drives: Camaro LS
Ill trade you mine! Its SW too!!!! Its got 2 very small nicks in the paint though....
LosingReality is offline   Reply With Quote
Old 05-28-2010, 09:02 PM   #11
Mach
Mach's Avatar
Drives: White M6 1LT RS
Mines a month old.. I'll trade. SW in Perfect condition.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 05-28-2010, 09:13 PM   #12
LEADfoot927
LEADfoot927's Avatar
Drives: 2012 GT500 SVTPP
Problem Solved!!!
http://www.slponline.com/view_product.asp?P=100038A
LEADfoot927 is offline   Reply With Quote
Old 05-28-2010, 10:26 PM   #13
Shuffler
God Bless Dawson
Shuffler's Avatar
Drives: Synergy for my Daughter
Good choice. I think most aftermarket hoods look better without the mail slot.
Someone on these boards will probably swap you straight up.
Shuffler is offline   Reply With Quote
Old 05-29-2010, 12:20 AM   #14
MikeSVX
The magic smoke genie....
MikeSVX's Avatar
Drives: Jewels (2010 RJT 1SS)
The mail slot plug from SLP would be alot cheaper.
MikeSVX is offline   Reply With Quote
2010 Camaro V6 Oil and Oil Filter Change azamazonqueen Camaro DIY & HOW-TO instructions & discussions 116 03-19-2017 02:36 PM
Richmond Gears V8 and V6 - Group Buy ZZcamaro Transmission / Driveline 175 04-30-2010 01:29 AM
**Swap you V8 front fascia for my V6 boomskeet USA - California 7 04-18-2010 05:52 PM
Okay to use ramps on V6 for oil change? philipdistefano Camaro DIY & HOW-TO instructions & discussions 4 01-31-2010 05:06 PM
