Old 02-06-2010, 03:12 PM   #1
4xchamp
MURC 666
4xchamp's Avatar
Drives: 69 Pace Car 68 Camaro Restomod 81 Z
Dynoed the LS3 today
Bone stock on 93 super , spiked with nos octane booster .
Made 391.5 ft lb and 378.7 hp .
Jumped to 405.5 ft lb and 393.2 hp with the air filter lid disconnected from lower housing .
Now that I've got a baseline the mods can commence .
Guys hoarding their Camaros are depriving some youngster the opportunity to restore it 25 years from now .
Drive it like you stole it , let the next guy baby it !
4xchamp is offline   Reply With Quote
Old 02-06-2010, 03:21 PM   #2
SSTony
SSTony's Avatar
Drives: SS Camaro
Send a message via AIM to SSTony
not bad on the numbers.
SSTony is offline   Reply With Quote
Old 02-06-2010, 03:50 PM   #3
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
i thought normal stock was in the 370s??
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 02-06-2010, 04:12 PM   #4
topgun1
topgun1's Avatar
Drives: 10 SIM 2SS/RS LS3
that's some serious #'s for a stocker! must be the octane booster?
5th Gen Camaros of the Carolinas SIM, 2SS/RS LS3 5/7/11 453.9 RWHP 427.5 RWTQ
VMS Stage 2.5 Comp Cams kit, Cold Air Inductions intake, ADM race scoop, DT 1 3/4" headers, Solo cats, 3" Magnaflow catback, Pypes cutouts, HP tune, H&R SuperSport springs, Eibach sways/spacers, TexasSpeed UD pulley, LSR tensioner pulley, Barton shifter, skip shift eliminator, powder-coated calipers, R1 concept rotors, StopTech pads, Granatelli wires, Lloyds mats, tint, AAC afterburner taillamps, AAC scanner/sidemarkers, SRP pedals, custom engine cover, black bowties, Ridergraphix hood spears....
topgun1 is offline   Reply With Quote
Old 02-06-2010, 04:28 PM   #5
4xchamp
MURC 666
4xchamp's Avatar
It was 378 hp , that is 370s . The open air cleaner housing picked up about 15 horse bringing it to about 394 hp . The octane booster was added to a full tank of 93 super .
Old 02-06-2010, 04:59 PM   #6
SSmuscle
SSmuscle's Avatar
Drives: 2SS/RS IBM
Whats your elevation?
SSmuscle is offline   Reply With Quote
Old 02-06-2010, 05:32 PM   #7
EuroCamaro
Drives: 2010 Camaro
The car was run on a Dynapac hub dyno so numbers are recorded at the hubs not treads....so less drive train loss and much more acurate
EuroCamaro is offline   Reply With Quote
Old 02-06-2010, 06:45 PM   #8
TommyTSquared
TommyTSquared's Avatar
Drives: RSSS
Accurate compared to what?
TommyTSquared is offline   Reply With Quote
Old 02-06-2010, 07:50 PM   #9
BLACK10
BLACK10's Avatar
sorry, that sounds way high for stock......
Old 02-06-2010, 07:50 PM   #10
Monte
Drives: '88 Monte Carlo SS, '10 Camaro SS
Unless you race on your Brembos a dynapack is less realistic and gives higher numbers than any other dyno. Sure his car shows more power but it will go just as fast as everyone else's.
-Chris
'10 Camaro SS
'88 Monte Carlo SS
Monte is offline   Reply With Quote
Old 02-06-2010, 08:21 PM   #11
rayhawk
rayhawk's Avatar
Drives: Camaro SS
What he is saying is that there is less error in the reading. It reads a bit higher but this type of dyno will typically result in less error from run to run than a traditional chassis dyno reading directly off the tire.
rayhawk is offline   Reply With Quote
Old 02-06-2010, 09:03 PM   #12
al ball
al ball's Avatar
Drives: blk ls3
good numbers---saw another LS3 in person had about same numbers. No run on my yet. Black/Beige SS-6M
al ball is offline   Reply With Quote
Old 02-06-2010, 09:21 PM   #13
4xchamp
MURC 666
4xchamp's Avatar
Sea level
Old 02-07-2010, 05:57 AM   #14
EuroCamaro
Drives: 2010 Camaro
Correct!
The numbers he has are higher ONLY because of the removal of the losses in the tires.
As there is NO error due to tire temp, size or pressure the results remain consistant.
This does not make his car any more powerfull (as it looks he is just above average for results I have seen on Camaro) just means he has a good base line to start mods from and when he returns to the same dyno, under the same conditions, he will get acurate comparisons.
always best to understand the science first
PRC CNC Ported LS3 Heads Going on the Engine Dyno Today!! Jason 98 TA Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 10-07-2009 05:33 PM
Ordered my Camaro today...fingers crossed! RS/SS Camaro Price | Ordering | Tracking | Dealers Discussions 9 08-26-2009 01:05 AM
LS3 automatic? 91t/a Camaro Price | Ordering | Tracking | Dealers Discussions 4 08-21-2009 08:58 PM
Some are saying that customer order production started TODAY GLBL WMR Camaro Price | Ordering | Tracking | Dealers Discussions 70 03-17-2009 12:07 AM
Didn't hear from dealer today, did anyone? Rob53 5th Gen Camaro SS LS LT General Discussions 4 02-20-2009 07:16 AM
