05-08-2009, 11:43 AM | #1 |
Drives: 2006 Dodge Charger / 2SS IOM Join Date: Dec 2008
Did Camaro (automatic) reviewers use tap shift ?
Something i have been curious about, when all of these road test were being done, was the drivers using the tap shift or just in drive. Without using the tap shift the car is going to try to conserve gas and short shift gears.
05-10-2009, 07:58 PM | #2 | |
Moderator.ca
The autos have 3 settings: normal, sport, and manual. Normal gives maximum fuel economy and smoother shifts. Sport firms up the shifts a bit and changes the shift timing. Manual is DIY but it seems like GM programed the auto to achieve maximum performance on its own. Manual is for fun more than performance.
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
05-10-2009, 08:00 PM | #3 |
Drives: CGM 2LT RS Join Date: Oct 2008
only the V8 has a sport mode.
and im pretty sure they were all in normal mode or sport if it was a v8. generally they would mention it if they had turned on the tapshifters |
05-10-2009, 08:19 PM | #4 |
Drives: 2007 Z06 Join Date: Oct 2008
Does the Camaro's A6 behave like the vette's - when in the manual mode the transmission starts off in 2nd gear.
Page 2-29 from the 08 Corvette Owner's Manual: Manual Paddle Shift While in the SPORT MODE (S) position, the paddles located on the steering wheel, can be used to manually up-shift or down-shift the transmission. While in the SPORT MODE (S) mode, push the paddle above the steering wheel spokes to up-shift to the next gear, or pull on the paddle behind the steering wheel spokes to down-shift to the next gear. To use the system, shift from PARK (P) position to SPORT MODE (S) while stopped and with the engine running, or from DRIVE (D) with the vehicle moving. When accelerating your vehicle from a stop in snowy and icy conditions, you may want to shift to second (2) or third (3) gear. A higher gear allows you to gain more traction on slippery surfaces. If the traction control is active, upshifts are delayed to increase your control of the vehicle. See Traction Control System (TCS) on page 4-6. While the Manual Paddle Shift gear selection system is active, the transmission will automatically downshift through the gears as the vehicle slows. The transmission will select second gear as the vehicle stops. From a stop, the vehicle will start from and hold second (2) gear unless the driver manually paddle shifts into a different gear or selects DRIVE (D). The driver can select first (1) gear for maximum acceleration from a stop. Notice how the driver must manually select 1st gear if he's using the paddle shifters. I know many of my Corvette buddies have been embarrased thinking that they selected Sport Mode for enhanced performance only to forget to shift into 1st gear. It's a goofy process that most folks aren't used to with an automatic. |
05-10-2009, 08:37 PM | #5 | |
05-10-2009, 08:41 PM | #6 |
Moderator
You use the same paddle to shift up and down. Remember to shift down from a stop when in sport mode in order to fully enjoy your acceleration.
Operation Demon//Buy at Invoice//RACECARWEAR RESPECT ALL CARS. LOVE YOUR OWN. warn 145:159 ban |
05-10-2009, 08:57 PM | #7 | |
Drives: 2LT RS CGM Join Date: Apr 2009
all autos have sport mode. they will stay in sport mode, until you start using tap shift, then its in manual mode. at least, thats what i understood
05-10-2009, 08:58 PM | #8 | |
and and one side it up, and one side is down.
05-10-2009, 09:03 PM | #9 |
Drives: 2017 ZL1, A10, White, sunroof, nav Join Date: Apr 2009
I'm pretty sure the up shift paddle is on the left and the downshift on the right
05-10-2009, 09:04 PM | #10 |
thankss, i wasnt sure which was which
05-10-2009, 09:22 PM | #11 | ||||||
Truth Enforcer
Drives: anything I can get my hands on Join Date: Sep 2006
upshift on the right, downshift on the left. Quote:
right button up shifts, left button down shifts here's the pic again.
A group as a whole tends to be smarter than the smartest person in that group until one jackass convinces everyone otherwise. Quote:
05-10-2009, 09:32 PM | #12 |
then what about normal mode? how would you change from normal automatic to sport automatic? thats the only thing i dont understand.
05-11-2009, 12:25 AM | #13 | |
Drives: 96 Bronco w/ a 5 speed Join Date: Mar 2007
It could be worse, imagine how embarrassing it would be if the car stayed in 5th or 6th and you tried to leave the light quickly... Slide the shifter from D to M. It won't go into manual until you use one of the "paddles." |
05-11-2009, 05:14 AM | #14 | |
The Automatic comes with 4 modes and in any of these modes you can use tapshift if you want by putting the car in M Normal: Car defaults on startup in this mode. Mode 2: No Traction Control but Stabiltrack Sport Mode: Automatic gearing changes a bit, traction control and stabiltrack is losened up for more spirited driving (Recommend for driving on a Track) Mode 4: Everything Turned off, grab you ass and hang on. You can easily kill yourself in this mode. Hope that helped. |
Similar Threads | ||||
Why aren't there any Aqua Blues yet? | txcamarogirl | 5th Gen Camaro SS LS LT General Discussions | 40 | 08-20-2009 10:05 AM |
Detroit News panel wants GM to build Camaro concept | Tran | 5th Gen Camaro SS LS LT General Discussions | 12 | 03-15-2009 04:38 PM |
4 SEMA CAMAROS finally unveiled by GM! (hi-res images & details) | FenwickHockey65 | Camaro Photos | Spyshots | Video | Media Gallery | 237 | 11-03-2008 10:39 PM |
edmunds drives the v6 !!!!!!! ???????? | i3litzkrieg | 5th Gen Camaro SS LS LT General Discussions | 47 | 09-02-2008 12:13 PM |
Car and Driver drives V6 Camaro! | Xanthos | 5th Gen Camaro SS LS LT General Discussions | 63 | 08-26-2008 09:21 PM |
