04-19-2015, 07:31 PM | #1 |
PDR F50 not functional
Had a buddy put my new amp in and after 3 hours of work it is not functional. There is an area on the top of the amp that should glow blue. It has no glow and yet we can test to see power making it to the in amp fuses. Anyone else run into this?
"Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!”
04-21-2015, 05:07 PM | #2 |
Drives: 2014 2SS RS Coupe Join Date: Aug 2013
if you know for sure you ran the power cable correctly, then try the remote wire, you can do a quick simple test, put the remote wire onto the battery and hook it up to the amp and see if it turns on.
GROUND ISSUE REMOTE WIRE ISSUE POWER WIRE ISSUE one of those 3. Don't leave the remote wire from battery to amp, just a simple test.
04-22-2015, 03:58 PM | #3 |
Got it figured out. Was the remote wire.
Thread Tools | |
