12-04-2022, 03:15 PM | #1 |
Drives: 2014 Yellow Camaro 2SS RS M6 Join Date: Oct 2013
Rear Spoiler Suggestions on a 2014?
Hello everyone! I just recently purchased a 2014 Bright Yellow 2SS RS Camaro. I was stripping off the rally stripes today to replace them with new ones and ended up removing the rear spoiler to finish the stripe removal. Then, I got to thinking what the back end would look like with a different spoiler on it. When I had my 2013 1SS RS rally yellow ride, I changed out the stock spoiler for a blade spoiler. It looked awesome! Should I do it again as the blade spoiler really looked meaty? What are your thoughts? Thanks!
12-04-2022, 04:29 PM | #2 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
Black Z/28 spoiler. Especially on your yellow car. Proper size and designed to be fully functional at high speeds. The problem (IMO) with the big double anvil super duper wickerbill whatever types is that they draw attention away from the rest of your car unless you go extra wild with other appearance mods for proper balance.
12-04-2022, 05:13 PM | #3 |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
I got one of these and is really nice https://www.amazon.com/Factory-Spoil...904010ad0&th=1
UPSTATE C5 MEMBER
12-04-2022, 05:16 PM | #4 |
Had it for 5-6 years
UPSTATE C5 MEMBER
12-04-2022, 05:56 PM | #5 |
That looks great vinman! Does it bolt right up like the factory spoiler?
12-04-2022, 05:57 PM | #6 | |
12-04-2022, 09:22 PM | #7 |
Valkyrie14
Drives: Chevrolet Camaro SS Join Date: Mar 2020
Brukshot, related question. What did you use to remove your stripes? Mine are beyond saving and I have to do the same.
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
12-05-2022, 04:53 AM | #8 |
I used a hairdryer on low heat setting and peeled them off by hand. It was pretty easy, I was surprised. It only took me a couple of hours. Then, I used goo gone to remove any residual glue left on which wasn't much at all. I first heated up the shop to 65 degrees for a couple of hours ahead of time so the whole car warmed up before I started.
12-05-2022, 08:46 AM | #9 | |
Valkyrie14
12-05-2022, 10:09 AM | #10 |
That's for sure Valkyrie! I'm over here in Omro on the Fox River and that is freezing up right now. I'm lucky that I have a heated shop to work in.
12-05-2022, 10:11 AM | #11 | |
12-05-2022, 02:59 PM | #12 |
Yes sir, doesn't use all 6 holes if I remember correctly, only 4 so have to plug the other two. Hopefully you don't have primer showing like I did when I took mine off:/
UPSTATE C5 MEMBER
12-05-2022, 03:42 PM | #13 |
Thanks vinman! I just ordered mine today from them. Yeah, and I have to pick up some touch up paint as the stock spoiler did a little scuffing on the ends.
12-06-2022, 01:46 AM | #14 |
Drives: 15 Camaro 2SS M6 Join Date: Jan 2020
