Old 10-28-2012, 01:34 PM   #1
Luvpilot
Luvpilot's Avatar
Drives: GM
Fieldgoal Harness, GTS covers
New Fieldgoal harness $90 shipped **SOLD**Original Wired Harness
----------------------------WIRED HARNESS INFO-------------------------
Just so everyone is on the same page with this wired harness your DRL lights will always be on when your headlights or halos
are on, you will not be able to turn them off at night if your headlights or halos are on. This is the same way the other vendor
harness operates
DRL STATES WITH WIRED HARNESS (Does not allow you to turn DRL’s on/off at night)
1. Light switch in “AUTO” mode ------ DRL’s come on like they were supposed to from the factory, then at night when your
headlights turn on the DRL’s will come on as well
2. Light switch in “Parking Light” mode -------- Your Halo’s will come on along with your sidemarker and rear parking lights
like the factory intended, however, now your DRL’s will come on as well
3. Light switch in “Headlight” mode ------------Your DRL’s will turn on also when this mode is used
4. DRL’s will stay on also when you turn your highbeams on
5. With the wired version of the harness, the DRL’s cannot be turned off at night, if this is necessary for you, AAC sells a very
nice LED flush mounted switch that you can mount on your dash. This switch simply can be wired into the 12V or Ground wire
supplied with the DRL wired harness to be able to turn the DRL’s on or off at night.
New GTS taillight covers. SOLD to nohemihere
Stickers have been removed
Includes Sidemarker covers, brand unknown
Sidemarkers with Headlight Armor dark smoke tint $90 shipped
Sidemarkers and VHT Nightshades tint. $75 shipped
Have been wetsanded and are ready for paint.
Check the other forums for alot more
Suck. Squeeze. Burn. Blow.
Luvpilot is offline   Reply With Quote
Old 10-28-2012, 09:02 PM   #2
nohemihere
nohemihere's Avatar
Drives: 2010 camaro ss white/purple
Ill take the tail light covers
nohemihere is offline   Reply With Quote
Old 10-28-2012, 09:57 PM   #3
Luvpilot
Luvpilot's Avatar
Drives: GM
Tailight Covers SOLD to nohemihere
Old 11-07-2012, 07:44 PM   #4
Luvpilot
Luvpilot's Avatar
Drives: GM
Price drop
Cmon people
Old 11-08-2012, 02:39 PM   #5
jimp23
Drives: 2018 ZL1 M6
money sent for DRL harness!
jimp23 is offline   Reply With Quote
Old 11-08-2012, 03:32 PM   #6
Luvpilot
Luvpilot's Avatar
Drives: GM
DRL Harness SOLD to jimp23
