01-01-2015, 02:33 PM | #1 |
KaBoom1701
Parking Manual transmission?
So while I'm waiting to go pick up my ZL1 tomorrow I decided to re-read the 13' Camaro manual to see if I can pick up any ZL1 tid bits....
Section 9-24 says to put the manual transmission in reverse and then shut the car off? I've always left my manual cars in 1st gear when parking. Any reason or logic to what the car manual recommends?
Mods:
01-01-2015, 02:36 PM | #2 |
The Great Punkin
Drives: 2013 2SS M6 Join Date: Oct 2013
Reverse gear is lower than first..
In past cars I've always used first because reverse always seemed to not engage quite right and would occasionally pop out. (Older cars) Also never used parking brake after I had one freeze in the winter. (again, old car) LOL
Who opened up a fresh box of idiots without finishing the old box, now they're everywhere!!
Tesla > Edison |
01-01-2015, 02:37 PM | #3 |
Drives: 2015 Redhot 1LE Join Date: Feb 2013
When parked at home I leave it in neutral since where i park its flat, other than that I park in either reverse or 1st depending on angle of slope.
01-01-2015, 02:39 PM | #4 |
Drives: '11 SS M6, '14 SS 1LE, '17 SS 1LE Join Date: Apr 2011
If I'm parking front end up hill, I put it in first. If I'm parked front end down slope, I put it in reverse.
Enjoy the ZL1 !!!
Anyone can drive fast in a straight line, its what you can do thru the curves that matters!
'11 CGM SS M6 ordered in 3/11, '14 BRM SS 1LE from stock in 10/13 & '17 HBM SS 1LE in 11/16 - all from BeckyD!! |
01-01-2015, 02:48 PM | #5 |
KaBoom1701
Ok, thx makes sense. Thx
Mods:
01-01-2015, 03:17 PM | #6 |
Drives: 2016 Camaro 2SS M6 Black Join Date: Nov 2013
01-01-2015, 05:42 PM | #7 |
Drives: 2016 SS Join Date: Jun 2011
I put it in first or reverse, whichever will do the least damage if I accidentally let the clutch out in gear at startup...
not that I've ever done that...
01-01-2015, 06:15 PM | #8 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
I have no idea what Chevy's logic is unless it's tied to the logic of an old anti-theft technique requiring you to put the transmission in reverse gear where movement of a back-drive linkage off the reverse lever on the transmission would then let you remove the key. Friend of mine with a '71-ish big-block Camaro had to deal with this.
Personally, I always leave any MT car in either reverse or 1st, and my choice of which depends mainly on which direction would cause the least damage should the car actually be able to start without the clutch pedal fully depressed. I've had cars that never had a clutch starter interlock to begin with (I am that old), a car with it that physically broke its little switch, and a car whose clutch interlock was such a PITA that inside two weeks I had intentionally and completely disabled it. Leaving a MT car in neutral is a lot like leaving an AT car in "N" instead of "P" - you've just thrown away the more reliable means of holding the car still for no good reason, and are now relying on the P-brake being in proper adjustment. Cables stretch, fray/unwind, freeze up in winter . . . just saying. Norm |
01-01-2015, 06:42 PM | #9 |
Drives: 1986 Chevy C-10 and 2013 BRM 1SS Join Date: Sep 2011
I have always parked manual transmiasion cars in first gear including my current Camaro. I wonder if it would be worth trying to retrain myself after all these years.
01-01-2015, 06:59 PM | #10 |
Drives: 2012 1SS Join Date: Aug 2012
Oh no not this again.
Reverse or first it doesn't matter, 30 years never had a mishap. Never has my car rolled into another while parked. Then there's the camp that wants to leave their car in neutral and put total trust in the parking brake.... that's risky.
Rowing through the gears of an SS Camaro always makes for a better day.
01-01-2015, 07:13 PM | #11 |
Depends on how I parked...
Head in = reverse Backed in = first
Past: '69 Chevelle SS396 '79 Camaro 400SBC/TH400 Present: '14 Camaro 2SS/1LE '03 Avalanche (tow car for...) Twin-turbo SBC Super Comp Dragster Future: FFR 33 Hot Rod w/ SBC RCR GT-40 w/ LS7 |
01-01-2015, 07:42 PM | #12 |
Drives: 2011 Camaro SS Cyber Grey Join Date: Apr 2013
Neutral and parking brake every time every vehicle. I've had over a dozen manual trans vehicles for 30 years including my 2013 Kenworth. That's 80,000 lbs on the parking brake.
01-01-2015, 07:50 PM | #13 |
Drives: 2011 2SS RS, 1968 ragtop Join Date: Apr 2009
I read in this forum that it also kept the battery from draining when parked in reverse. Don't know if true, but plenty of stories on C5 about older Corvettes and dead batteries due to the issue. Since it's in the owner's manual I've been doing it on both Camaro M6 cars since 2009. Common sense, too, always use e-brake.
1968 Camaro Convertible LS1, T56
01-01-2015, 09:11 PM | #14 |
Drives: 2014 1SS / RS M6 Join Date: Dec 2014
Usually in 1st with parking brake on in all situations. With my old 73 Z/28 Muncie M22 it had to be in reverse. Lift up and to the left to remove the key.
