Old 06-27-2015, 12:42 AM   #1
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Best Product for Headlights?
I am going to be installing a heritage grille and with that i will gain complete access to my headlight housing and the ability to shine them up a bit better. What product have you found to be the best out there for my type of application? I don't have any yellowing or discoloration.. Just want to bring them back to life a bit while protecting them for the rest of their life span.
Nighthawk89 is offline   Reply With Quote
Old 06-27-2015, 06:53 AM   #2
seven
seven's Avatar
Drives: 2015 Camaro RS 2LT AGM
I actually messed mine up by hand applying a too aggressive Polish to get some marks off mine only a week after I got her. Ugh! Advice on forum so helpful. I got a 3 inch backing plate for my DA polisher and used a finishing Polish menz 4500 and it removed the scratches and they looked crystal clear. I then sealed them.
2015 RS Camaro 2LT with Sunroof, Performance Exhaust, Ground Effects, Tinted Windows, LED Fog Lights(DD), CAI Cold Air Intake, Ghosted Side Markers(Showstopper), Elite Catch Can, Xpel & SunTek PPF, Replica Z28 High Wing Spoiler, ZL1 Replica Wheels(Satin Black Factory Reproductions)
seven is offline   Reply With Quote
Old 06-27-2015, 08:03 AM   #3
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
meguiar's plastx will do what you are looking for. But I don't recommend it until you get yellowing because you're shortening the lifespan of your factory coating
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 06-27-2015, 08:06 AM   #4
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
A protective film to cover them will provide you with more durable protection vs. a sealant. There is no product I know of that will last permanently on them, the film usually lasts between 3-5 years.
Joe M 2012 2SS is offline   Reply With Quote
Old 06-27-2015, 10:38 AM   #5
Bad@ssCamaro
BeckyD Rocks :-)
Bad@ssCamaro's Avatar
Drives: 2015 1SS/1LE
I would definitely add the Xpel headlight protection film after you polish the lens to prevent any further damage to the lens. After a few years, you can replace the film and the headlights will still look great (as long as they didn't get hit hard by flying debris) Less maintenance for sure.
Old 06-28-2015, 08:33 PM   #6
revived
Vrrrm.
revived's Avatar
Drives: 2011 2SS/RS LS3
I had tons of rock chips, I bought a 3m restokit and it worked wonders but to get perfect results you need to wet sand instead of dry and really take your time.
the real trick to finishing was using blackfire compound leaving the residue then hitting it with there polish over top... then plast x to really make them pop.
it takes a while though...
revived is offline   Reply With Quote
Old 06-28-2015, 08:56 PM   #7
seven
seven's Avatar
I have Xpel Ultimate on my headlights.
Old 07-03-2015, 02:31 AM   #8
rdanzel
Drives: 2010
How about using Opti-Lens headlight coating. It provides permanent solution.
rdanzel is offline   Reply With Quote
Old 07-04-2015, 12:52 PM   #9
nUcLeArEnVoY
Oldbie that nobody knows
nUcLeArEnVoY's Avatar
Drives: 2011 1SS/RS M6
I have a bit of a different answer for you, since you say you have no yellowing or discoloration; so this is telling me that your issue may have nothing to do with the outside of the lens. Also, your car is placed right within the model year range where what you're about to read is a common problem.
After a few years, RS headlights typically get a film of residue that forms on the *INSIDE* surface of the lens, making the headlight appear hazy when lit. Believe it or not, our RS headlights are vented, and the headlamp housings "breathe" as they heat up and cool down. When they "inhale" (as they cool) they suck in air, water vapor and whatever crap is in the air at that time. Smog, oil mist from the engine bay, beer farts, whatever. All of this crap condenses on the interior surfaces in an even coat and will remain there, building up, forever. One trick to removing this residue is to remove the headlights and pour around half a cup of 100% methanol in through the back opening (has to be 100%, or else it will leave water stains), swish it around for around a minute along the inside of the lens, pour it out, and repeat the process 4-5 times until all traces of the residue and debris are gone. It will dissolve the residue without harming anything else, leaves no stains, and restores crystal clear clarity. After the last repetition, you then take a blowdryer and just aim it inside the headlight on a cool setting for around 5 minutes and then give the headlights another 20 mins or so to completely dry. Methanol is a polar solvent, so it is a drying agent in and of itself. It will dry relatively quickly. I've done it myself and it works wonders.
Another thing that commonly happens with RS headlights is that the halo LED begins to burn cooler as it ages, which causes the color of your halo to become more yellowish as time goes by, as opposed to the pure white from when they were new. Fixing this would require replacing the halo LED with a new one.
Whatever you do, do not bake and open your headlights if you decide to perform these interventions. You can get the halo LED chip out without having to bake and pry open the headlights - it's a pain, but worth it knowing your headlights are still factory sealed.
nUcLeArEnVoY is offline   Reply With Quote
Old 07-04-2015, 01:15 PM   #10
Nighthawk89
Great Advice forsure!!! I wish someone offered the led replacement. I would deff send my Headlights in for this service. I always see a newer model SS with thos damn bright LeD rings and im not going to lie. It looks really good!
Old 07-04-2015, 01:25 PM   #11
nUcLeArEnVoY
I can link you to a website where you can get replacement LEDs. In fact, the kelvin level (temperature) on these replacements is a little higher than the factory LEDs, so they have an even purer white hue to them. At that point, your job would just be to have them sent in to make the replacement.
If you decide to do the methanol trick, I would do that yourself. If you send it to your dealer, they might pry open the headlight and just wipe the residue off the inside of the lens. Bad idea, since the plastic is very delicate and will scratch easily; and you don't want scratches on the inside of the lens.
Old 07-10-2015, 12:06 AM   #12
cadelennon
Drives: '15 Camaro 1lt,
I wax mine after every wash! other than that i don't worry too much about them.
cadelennon is offline   Reply With Quote
Old 07-10-2015, 12:10 AM   #13
Nighthawk89
Who does the led replacement?
Old 07-10-2015, 06:46 AM   #14
nUcLeArEnVoY
Osram. You want the Platinum Dragon SMD.
