Old 07-13-2015, 04:22 PM   #1
SargeantSarcasm
SargeantSarcasm's Avatar
Drives: 2013 ZL1 M6
Polish/pad combos
Hey guys...going to spend a day polishing my car out. What's a good go to polish/pad combination for a 2-3 step correction?
SargeantSarcasm is offline   Reply With Quote
Old 07-13-2015, 04:38 PM   #2
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
Cyan Hydrotech FG400, Tangerine Hydrotech Optimum Hyper Polish. That combo right there gets 90-95% perfection on just about any car.
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 07-13-2015, 06:03 PM   #3
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
For a high gloss after compounding, Carpro Reflect with Crimson LC Hydrotech pad.
If your defects are light and don't need compounding, Reflect finishes well with the Tangerine LC Hydrotech pad.
I see on weatherforyou.com that the temperatures are going to be hot for several days in your area.
When it's hot outside, your compound/polish will tend to dry up quicker. So if your not working in a temperature controlled environment, I'd consider waiting until you have a range between 60* and 80*.
You could do it in the early morning if possible for you to start then, but you may have to split it up into 2 or more days depending on the amount of correction/polishing needed, and the type of machine used to do the correction/polishing.
Joe M 2012 2SS is offline   Reply With Quote
