Old 08-05-2016, 05:09 PM   #1
CFrance
CFrance's Avatar
Drives: 2013 ZL1, 2013 LS
Help with Caliper to Knuckle Bolts Part Number
Hey guys,
I am going to be putting new pads and rotors on my ls camaro this weekend but I was reading this morning and found that on the v6's you have to remove the caliper in order to get the pads out (this I already knew), the part I didn't know is the bolts that hold the caliper to the knuckle are TTY bolts and GM suggests replacing them each time you remove them.
So I was just at the nearest chevy dealer trying to order the bolts so that I could put new ones in but the part numbers that I found on the forum and the ones he gave me are different.
Here is the part numbers the dealer gave me:
Front: 11570092
Rear: 92139142
Here is what I found on the forum:
Front: 11570788
Rear: 11515781
Can anyone confirm which one is correct?
Thanks guys!
CFrance is offline   Reply With Quote
Old 08-05-2016, 05:30 PM   #2
clarkkent
Drives: 2013 2SS (sold)
I just did some work on my fronts and I used 11570788, however I have SS Brembos
clarkkent is offline   Reply With Quote
Old 08-05-2016, 06:21 PM   #3
CFrance
CFrance's Avatar
Thanks! I was thinking the difference in part number could just be because the ones on the forum are for a v8 and mine would be a v6 but I am just trying to get some confirmation.
I have to pay for the bolts before they can order them so I want to make sure I am getting the right ones.
Old 08-05-2016, 06:28 PM   #4
clarkkent
It's weird, the site I usually use to check parts shows the rear caliper and bolt as one part (#4, scroll down) http://www.iamgmparts.com/auto-parts...omponents-scat
And I can't find the bolts for #6, which is the fronts at the top
Old 08-05-2016, 06:47 PM   #5
BLU DUCE
BLU DUCE's Avatar
All the dealer parts man needs is your Vin Number for the right parts number. Unless he don't know what order numbers go in.
Old 02-23-2018, 04:23 PM   #6
JamesU
Guest
Posts: n/a
I'm replacing the rotors on my wife's 2011 SS for the first time and ran across this caliper bolt stuff in the Service Manual, saying the bolts should not be reused. The tightening spec is also odd, stating 30 ft-lbs + 90 degrees. Are these bolts yielding during tightening, making them non-usable a second time? Or is it simply a concern about the loc-tite?
I bought these parts online:
Front: 11570788
Rear: 11515781
but the package still hasn't arrived. It seems odd that for a part that is supposed only be used once, and tossed, that it is not very easy to get the right replacement bolts. They are not sold as kits. No dealership in my area had 4 of any of them in stock.
Thanks!
Old 02-23-2018, 04:32 PM   #7
clarkkent
Front: 11570788
Rear: 11515781
Thanks!
Hi James,
Yes, there are TTY (torque to yield) bolts. They actually stretch during the 90 degree tightening action. So theoretically the bolt is always under tension. The reason for this is because the calipers have large temperature swings, and they do not (for obvious reason) want these bolts getting loose.
That being said, I've seen people reusing the bolts fine.
Odd that no dealership has them in stock. I bought mine from Amazon, you need 4 to do both calipers. They're the same on each side, so you can just get 4 of this part number if you want. https://www.amazon.com/General-Motor.../dp/B008Y8QZPY
Old 02-23-2018, 05:54 PM   #8
Cheetoh
Drives: 2011 Callaway SC572, 2000 Firehawk
Hi James,
So.... Would you Torque the bolt to 30 Ft/lbs and then go another 15 minutes?
2011 Callaway Camaro, 572 H.P
Cheetoh is offline   Reply With Quote
Old 02-23-2018, 05:56 PM   #9
clarkkent
Correct. I think the front might be 44 ft/lbs though. Rears 30 ft/lbs.
Old 02-23-2018, 06:51 PM   #10
Rainbow1616
Rainbow1616's Avatar
Drives: 2011 Inferno Orange Camaro 2SS/RS
I reused mine a year ago. No issues whatsoever. I checked them at about 8 months and they were still as tight as when I put them on.
Rainbow1616 is offline   Reply With Quote
Old 02-27-2018, 03:47 PM   #11
Buckeye
Buckeye
Drives: 2013 2SS RS 1LE
Interesting. The dealers don't stock these bolts. What do they do when a car comes in for service and it needs to have the calipers removed? I'll bet they reuse the bolts and get the car repaired and back on the road.
Buckeye is offline   Reply With Quote
Old 02-27-2018, 05:19 PM   #12
hammdo
'It's an experiment'
hammdo's Avatar
Im using one of our sponsors reusable bolts for my ZL1 brake upgrade:
Front 6 pots:
https://www.ebay.com/itm/CTS-V-Camar...item1a1bb4d550
Rear (same bolts for SS front Brembo’s):
https://www.ebay.com/itm/CTS-V-Camar...item28269caeaf
May help some folks...
-Don
747 RWHP 794 RWTQ
