Old 06-14-2017, 03:54 PM   #1
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
Can you put on a 2015 SS exhaust on 2010 v6 camaro?
My catalytic converters went bad a few thousand miles after the warranty ended (go figure). It's cheaper to replace the entire exhaust than just the cat converter, so wondering if anyone can shed light if I can make this replacement?
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 06-15-2017, 09:10 AM   #2
MattIdaho
MattIdaho's Avatar
Drives: 2014 2SS/RS
anything is possible, but imo it would be far from a direct bolt on.
MattIdaho is offline   Reply With Quote
Old 06-15-2017, 09:46 AM   #3
partlowr
partlowr's Avatar
Drives: 2011 2SS/RS Convertible
The bigger question is why???
Richard Partlow
partlowr is offline   Reply With Quote
Old 06-15-2017, 01:50 PM   #4
ihaveacamaro
I like teeth.
Drives: #198
Why do you say that? The 2012 SS exhaust I have on my car was a direct bolt on. Is there something fundamentally different than before?
Catalytic converters from dealership = $1000
Take off SS exhaust on craigslist = $150
Old 06-15-2017, 03:24 PM   #5
PROZ11
PROZ11's Avatar
Drives: 2012 RS/2SS, 69 ProStreet Camaro
The Craigslist exhaust includes cats for $150.00??? If so, those cats alone are worth much more than that but won't work with a V6..
I gave my factory V8 6 spd cat back exhaust to a friend with a 2010 V6 auto and he said he swapped it with his factory set up with no problems.
PROZ11 is offline   Reply With Quote
Old 06-15-2017, 03:39 PM   #6
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
I doubt that the cats are not included in that $150 price.
The cat-back sections between the two would be the same except for the larger pipe (2.25" vs 2.5"). However; I'm not sure if the flanges where the catalytic converters mate up to the exhaust manifolds are the same between the 2010 V6 and the SS.
I know you can get magna flow direct fit from Oreilly's...$355 each. Or get universal cats (a lot cheaper about $70-100) and have a muffler shop weld them in
nancygrl is offline   Reply With Quote
Old 06-19-2017, 07:56 AM   #7
ihaveacamaro
I like teeth.
Drives: #198
Thank you! I'm glad to hear that! Cats are included
Ok, if it doesn't work out for any reason, I'll try one of these methods, thank you!
Old 06-20-2017, 08:12 AM   #8
PROZ11
PROZ11's Avatar
I thought what you needed was cats? They are not the same V6 to V8. The cat back is interchangeable V6 to V8 but the cats are not. So a full V8 exhaust with cats is not going to help if your cats are bad.
