Old 06-25-2017, 06:37 PM   #1
Cheetoh
Drives: 2011 Callaway SC572, 2000 Firehawk
Help.. I have tire rub!!
I am running 285-35-20 tire on the front and 305-35-20 tires on the rear. I occasionally get tire rub on the inside fender on the front. Any idea on what I can do to get rid of the rub?
2011 Callaway Camaro, 572 H.P
Cheetoh is offline   Reply With Quote
Old 06-25-2017, 07:05 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
Lowered? If so how much? What are your wheel widths/offsets? What is your camber?
KillboyPowerhead is offline   Reply With Quote
Old 06-25-2017, 07:28 PM   #3
hatesnow
Drives: 2011 SS Camaro
Wheel spacers perhaps? I'm no expert.
hatesnow is offline   Reply With Quote
Old 06-25-2017, 07:29 PM   #4
Cheetoh
Car is lowered 25 mm. I have 11" Rims on back and 10" on the front. Not sure of the offset, but was told it is the same as the ZL1. No idea what the Camber is at all. Do you think it may just be a Camber issue? The rub it on the outer edge of the tire.
Old 06-25-2017, 07:32 PM   #5
hatesnow
I just had new wheels installed on my ss 10 inch on the front also and I know they used wheel spacers on the front. I have no issues.
