10-12-2019, 05:33 PM | #1 |
Drives: 2011 Callaway SC572, 2000 Firehawk Join Date: Nov 2009
Easiest way to realease Fuel line Pressure.
What is the easiest way to release the Fuel line Pressure on my 2011 LS3 Camaro?
10-12-2019, 06:18 PM | #2 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
pull the fuse and start the engine, run engine till it quits
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
10-13-2019, 08:20 AM | #3 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Open the gas cap and push the relief valve on the fuel rail
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
10-13-2019, 09:25 AM | #4 |
Drives: 2014 Camaro 2SS Join Date: Feb 2015
Opening the gas cap will have no effect on fuel pressure. The correct way would be to use a fuel pressure gauge, they have a button on them to release the pressure. Or, just disconnect the line and have a rag over it when you do it, being ready to soak it all up.
10-13-2019, 11:44 AM | #5 |
I would figure the Schrader valve is the easiest and gives good access for a rag or drip cup. It is how I do it.
10-13-2019, 06:04 PM | #6 |
Drives: Never just fly under the radar Join Date: Jul 2015
Do this
Old Skool |
10-13-2019, 09:40 PM | #7 |
Drives: Camaro Join Date: Oct 2018
