02-04-2013, 02:42 PM | #1 |
Drives: 2013 2SS/RS Victory Red Join Date: Jul 2012
CEL help
Took my car to autozone and had them check codes and said I had 4 all O2 sensor delays is this something major? And I have CAI intake with ported tb
02-04-2013, 02:44 PM | #2 |
Drives: 2010 Camaro 2SS/RS Join Date: Dec 2009
How is it running?
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10. ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller. |
02-04-2013, 02:46 PM | #3 |
knows 2 facts about ducks
I'd take it to the dealer just in case.
02-04-2013, 02:48 PM | #4 |
Drives: 2021 1LE Join Date: Jul 2011
If there are no headers installed... something may have come un plugged with the cai and tb install. Check all your connections if the cels don't clear head over to the dealer.
02-04-2013, 02:50 PM | #5 |
If he does as soon as they se the Ported TB, that will be the problem. I agree he need to check all the connections. If possible put the stock, or a stock tb back on and see if this fixes it.
02-04-2013, 02:59 PM | #6 |
It took 3 weeks after I had intake tb put on and I think it started after I took it to the track with em on and it goes off and comes back on every few days or a week
02-04-2013, 03:04 PM | #7 | |
But in regards to the dealer finding the ported TB and denying warranty because of it - I'd doubt it. Only way they'll see it's ported is if they remove it and inspect it under a bright light. Even then, the tech would have to know what a ported TB looks like vs. a stock one. |
02-04-2013, 03:18 PM | #8 |
Will getting a tune help this situation or no?
02-04-2013, 03:35 PM | #9 |
02-04-2013, 03:55 PM | #10 |
It could yes, depending what's causing the CEL. But with your mods you shouldn't need a tune.
02-04-2013, 03:57 PM | #11 |
Didn't think so but I may get headers so I need to know if I need to get this fixed first
02-04-2013, 04:15 PM | #12 |
Drives: 2014 1LS M6 Supercharged Join Date: Feb 2011
I had the same problem when I installed my Headers and CAI, Getting a Triffecta Tune fixed that, and I also got a nice jump in HP. If you can get Headers, I would wait until you have them installed, then get the tune.
02-05-2013, 01:22 AM | #13 |
They found mine. But it did not matter as I was already out of warranty.
02-05-2013, 02:16 AM | #14 |
Drives: '11 SW 1LT RS Join Date: Aug 2012
Could this be from CAI cleaning oil? if you put too much it can mess up your sensor..
