01-05-2015, 05:54 PM | #1 |
IECC
Drives: 2010 2SS/RS IBM Join Date: Jan 2010
Applying Wax with PC
Every 6 months I clay/polish/wax my car with a PC. Will the PC eventually deteriorate the clear coat? I took my DD to get washed/clayed/waxed and I told the guy that I always applied polish/wax using my PC. He gave me a look as if I had committed a detailing sin. Should application method be altered? (i.e. by hand vs. machine)
Thanks.
2SS/RS IBM
Mods: CAI Intake, Eibach Springs and Sway bars, Clear Bra, Borla Sport Catback, AAC Side Markers, DJG Phantom Hidden Headlight Grille, Suncoast Creation Functional Hood, Anvil Notched Spoiler, Custom Painted Stripes, Mail Slot Delete, 3D Carbon Fender Vets |
01-05-2015, 06:17 PM | #2 |
Smoke Alotapotomous
Drives: 2010 Camaro SS Join Date: Jun 2011
Should be fine if you're using a softer pad. Ie blue or black
2010 Camaro TT SS. AGP twin Turbo
01-05-2015, 06:18 PM | #3 |
+1
[B]
01-05-2015, 06:22 PM | #4 |
Raised by Wolves
Junkman says the only way you're gonna hurt your paint with a pc is if you hit the car with it like a club. Dude was just probably flabbergasted that you knew how to do any let alone all of that stuff. I do wax by hand though cuz by that time I'm pretty tired of hanging on to that PC.
01-05-2015, 06:28 PM | #5 | ||
Drives: The shiny ones. Join Date: Mar 2010
Polishing is an abrasive process that does remove a microscopic amount of clear each time its done. Assuming you go with mild approaches only to address very fine imperfections its not enough to worry about - there is plenty of clear (relatively speaking) from the factory to work with for a long time. Waxing is non-abrasive. You're depositing a coat of something over the paint so no material is removed. So long story short, you're fine. The only process that removes material is polishing and even that needs to be done in excess to be an issues. Quote:
EDIT - by the way... former IE resident myself... I lived in Rancho Cucamonga/Etiwanda almost all my life until we moved here to Colorado just over 2 years ago. |
01-05-2015, 06:56 PM | #6 |
IECC
Thanks everyone for the advice.
2SS/RS IBM
01-06-2015, 09:06 PM | #7 |
I can't add anything to the process advice above, it's spot on.
I wouldn't assume a look to mean something, I would ask him what his procedure/technique is. If the car comes back looking better than your way, he might help you with your detailing skills. If his advice differs from the above, you might want to consider someone else. |
01-07-2015, 07:40 AM | #8 |
Drives: 2013 Corvette 2LT Join Date: Feb 2012
