01-15-2023, 05:12 AM | #1 |
Drives: 2016 1LT RS Convertible Join Date: Apr 2013
FS 17" rims 34 Offset, With old winter tires $100, South of Boston
Pick up only about 10 miles south of Boston. Trying to clear out my shed. I bought these in 2013 for my Camaro 5. They were excellent in the snow. At this point the tires have been used about 50K and have sat in a shed for 6 years. I do not recommend that they be used. Otherwise the rims are in good shape, the TPMS is for a Camaro 5. Pick up only. Here are the specs from the Tire Rack receipt. They should work on the LT models with the standard brakes. A 17 inch rim is great for snow tires and pot holes.
17X7.5 5-120 ET34 MSW TYPE 14# 89.00 W29030001C09 (72.5 CB) TL 72.62-67.10 CENTER RING N/C 72-6706 / C72-6710 NC14X1.5 CLSD SD TUNER-NUT LG N/C (EXTERNAL SPLINE)50TL 26148HT 13/16" 7/8" SPLINE DRIVE LG N/C FOR EXT DRIVE WITH .91 OD SCHRDR 315MHZ RUBBER V. SENSO# 49.00 RUBBER VALVE PRE-INSTALLED OPTIONAL SILVER METAL VLVE 4NM 3.99 VS-925A 4NM=35IN.LBS 225/65R17 MI LAT X-ICE XI2* # 142.00 21499 102T |
