Old 05-21-2014, 08:39 AM   #1
Moreno1
Drives: G5.R
OVER 200 LBS. IN WEIGHT SAVING IDEAS
Hey guys we have gotten a lot of PM's regarding advice on weight reduction options from members over the last two years and thought it be a funny idea to create a weight reduction thread were we can share and discuss different options on reducing perhaps some additional weight off the Z/28 as I know understand that GM is catering to the enthusiast market and this would be a topic of interest. We can discuss from mild changes that could be easy reversed to the more aggressive changes for the guys who aren't concern with collectibility factor 40 years down the road.
Perhaps you guys could share what your weight drop goals are and we can discuss different options on how to get there.
So lets start and here some of the ideas, pros, cons, etc.......
Perhaps this might become a "sticky" thread for other members to benefit down the road so lets try to keep it on topic!
Moreno1 is offline
Old 05-21-2014, 09:06 AM   #2
LehmanZ06
Drives: Z28 want
No washer fluid
Take off Z/28 emblems !
Toss flow tie
Rip out radio.......
LehmanZ06 is offline
Old 05-21-2014, 09:08 AM   #3
Zfatuated
Zfatuated's Avatar
Drives: BAC Mono
Excellent thread idea
1. Ti cat-back exhaust. Save 40 lbs? That's a guess. Approx $3k-4k. Only con is $
2. LiON battery. Save 30+ lbs. Approx $1500. Only con is $. High-quality Lion exceeds lead acid in every way.
That is your quickest, easiest, biggest lb numbers. I would have zero interest in anything that compromises the structure/safety.
Maybe some kind of plastic/carbon intake, save 5 lbs? Big $$?
2014 Z/28, White
"I wasn't asked to make it cheap...I was asked to make it FAST!" Mark Stielow, the new Z/28.
Zfatuated is offline
Old 05-21-2014, 09:32 AM   #4
brt3
Runs with scissors...
brt3's Avatar
Drives: '14 Z/28s SIM/SW
Question -- is anything special required regarding charging, etc.? For some reason I recall this being an issue with first gen versions...
brt3 is offline
Old 05-21-2014, 09:49 AM   #5
Xlr8ion
Drives: 2013 Cayenne GTS
Go on a diet...
Xlr8ion is offline
Old 05-21-2014, 09:52 AM   #6
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Strip the paint down to the bare metal then use a tinted clear coat over it. That might save a couple pounds.
The Bird is the word!
Angrybird 12 is offline
Old 05-21-2014, 09:53 AM   #7
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
http://rearseatdelete.com/camaro5.html
I know the Z/28 has a lighter-weight rear seat as is, but this might be even less....
Pros: More cargo room.....(track tires)....
Cons: Not usable for passengers....(No seat belts)....
90503 is offline
Old 05-21-2014, 10:10 AM   #8
Moreno1
Drives: G5.R
I haven't heard this one yet in the Z/28 section... CF one piece drive shaft. reduce some driveline weight, and at the same time you get rid of the slop that comes with a two piece.
OE wheels are beautiful, but not the lightest at 25-27lbs ea. We have forgeline Ga1R-OL and they are right under 21lbs ea IIRC
Optic Armor front and rear windshields will save 20 lbs off the top of the car.
all depends on how extreme you wanna go
Moreno1 is offline
Old 05-21-2014, 10:13 AM   #9
brt3
brt3's Avatar
Going all "Silver Arrows" on us, eh?
brt3 is offline
Old 05-21-2014, 10:28 AM   #10
Zfatuated
Zfatuated's Avatar
Drives: BAC Mono
None whatsoever. Out with the lead-acid, in with the LiON. I've done it many times on other cars.
If this kit eliminates the seat frame then the engineers are are record that the frame is necessary to contribute to chassis rigidity. That is why they left it in. ABS plastic is no substitute in that case. That is not a compromise (weight/rigidity) I would want to make.
Love the ideas!. However, I am under the impression non-glass (lexan/polycarbonate) windows are not street legal in the US? Am I wrong?
What would a drive shaft cost? Weight savings?
2014 Z/28, White
Old 05-21-2014, 10:31 AM   #11
Apex Paul
Apex Paul's Avatar
Drives: Wagon Queen Family Truckster
we have LiON batteries for a lot less than that, around $300.
Apex Paul is offline
Old 05-21-2014, 10:31 AM   #12
brt3
brt3's Avatar
I haven't heard this one yet in the Z/28 section: CF one piece drive shaft. reduce some driveline weight, and at the same time you get rid of the slop that comes with a two piece.
OE wheels are beautiful, but not the lightest at 25-27lbs ea. We have forgeline Ga1R-OL and they are right under 21lbs ea.
I've thought about the CF driveshaft as there was a group buy for these on the C5. I'm going with Finspeed wheels and I expect them to be very close to 20 pounds even. All 4 OEM wheels measured over 27 pounds when I weighed them during my recent tire switch...
brt3 is offline
Old 05-21-2014, 10:33 AM   #13
90503
90503's Avatar
....I was surprised how "cheap" my stock SS rear seats were....There is no frame...They are more like couch "cushions"...lol...Don't think you will lose any chassis rigidity by changing them....
90503 is offline
Old 05-21-2014, 10:37 AM   #14
Moreno1
Drives: G5.R
Well the $1500 ones will most likely have fail-safe computer tech in the battery to prevent full discharge, low/overvoltage, shorts, etc. Call lithium pros and they'll explain everything to you, as a lot of the tech is beyond me. LOL. from what I have seen, they have the most tech, and highest size/weight ratio... i.e. they are very light
Moreno1 is offline
