Old 07-29-2014, 08:39 PM   #1
Moreno1
Drives: G5.R
Camber/Caster plates!!!
These are NOW AVAILABLE! Click here for a link to the sale thread!
CLICK HERE FOR INSTALLATION GUIDE
ORIGINAL POST
Hey all,
Currently in the prototyping phase. No timeline as for when they will be available, but I am doing my best to expedite these. I am determined to bring you guys the BEST solid mount adjustable top plates for your camaro, and I have spent countless hours planning, drawing, and revising my design to make sure that it is so.
Here are some of my goals for this product and notes on its advantages.
- One design, that will work for ALL struts, OEM or aftermarket.
- NO drilling required.
- The versatile design will allow you to position the strut for max camber, max castor, or any split between camber and caster. INFINITE camber/caster split adjustability.
- Laser etched measurement hash marks allow for precise adjustments.
- 18 mm adjustability at the plate.
- If plates are positioned for camber only or caster only, adjustability is increased by 1.45 degrees for the corresponding angle.**
- If plates are positioned at 45 degrees for a 50-50 camber/caster split, adjustability is increased by 1 degree for both angles.**
- bulletproof 3/4" ID Spherical bearing at the top has the ability to carry much more load than 5/8" bearings that are typically used in camber plates. Spherical bearing allows unrestricted strut articulation unlike factory rubber upper mount.
- 20mm ID, double sealed, single row, radial ball bearing isolates strut shaft rotation, and removes steering load from the top spherical bearing.
- Rubber padding adhered to upper spring perch removes metal to metal contact and greatly reduces sharp noises when going over bumps or potholes.
- Made in the USA.
** note: range of adjustability is dependent on distance from pivot point to plate (i.e. ride height). given numbers are +/- .05 degrees.
Updated photo:
Name:  Camber plate assy.jpg
Moreno1 is offline
Old 07-29-2014, 09:39 PM   #2
tw78911sc
tw78911sc's Avatar
Drives: 14 1SS Camaro 1LE, NPP, Recaros
Bless you, put me on a early list tw78911sc@yahoo.com
tw78911sc is offline
Old 07-29-2014, 09:56 PM   #3
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
Hell yeah! I'm in for stock strut style.
LMS Engineering
White_SS/RS is offline
Old 07-30-2014, 07:36 AM   #4
Denis
Denis's Avatar
Drives: 2010 SS
ooooooooooooooooo very curious
Denis is offline
Old 07-30-2014, 08:57 AM   #5
Mean Green Z28
Drives: 2010 2SS
nice! I like how it's designed so that you can rotate it and pick between more caster/camber adjustment!
2010 2SS - CAI Intake, ADM Scoop, RotoFab Washer relo. LT Headers and off-road pipes, X-pipe, Muffler Deletes, ZL1 Spoiler, Technostalgia Tail-lights
'98 T/A (Sold) - Forged 6.0ltr, MS3, P&P'd Heads/Valves, 90MM FAST/TB, Headers, 3" Y-pipe, 4" Mufflex Catback. Koni Adjustables w/GC coilovers (550/175), Strano Sway Bars
'94 Z28 (Sold) ... LS1 swap (basically same setup as the T/A), TH350/3500 stall ... swapped it all into the T/A
-- >> Some of my Projects My Fquick Page
Mean Green Z28 is offline
Old 07-30-2014, 11:47 AM   #6
Moreno1
Drives: G5.R
Thanks all!
I updated the OP with some more details.
Moreno1 is offline
Old 07-30-2014, 05:45 PM   #7
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Nice! definitely filling a void here. I'll be keeping an eye on this.
Best regards,
Tyler
888-308-6007
JDP Sales is offline
Old 07-30-2014, 07:57 PM   #8
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
Interested in a set to fit Pfadt's feather light coil overs. Subscribed.
bannonm is offline
Old 07-30-2014, 09:54 PM   #9
BLTZKRG
Drives: 2014 Camaro SS
Interested for stock setup provided they clear the 1LE strut brace
2014 Ashen Gray Metallic 2SS/RS M6
CAGS Skip-Shift Eliminator
1LE Strut Tower Brace
GMPP Track Pack Axleback
Halltech CAI
Fuse Pull Mod
BLTZKRG is offline
Old 07-30-2014, 10:02 PM   #10
AG1LE
AG1LE's Avatar
Drives: '14 1LE
Looks great - any idea how much you might ask for them?
AG1LE is offline
Old 07-30-2014, 10:19 PM   #11
Zombie killer
Emerald Coast Camaros
Zombie killer's Avatar
Drives: 2013 2SS/RS L99
Pick me pick me !!! Lol. Can't wait to see how they work on stock struts too. Looks promising tho. Put me on the list too.
Zombie killer is offline
Old 07-31-2014, 03:58 AM   #12
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
What color will they be??? An will be watching this also!!!
olblue75 is offline
Old 07-31-2014, 01:14 PM   #13
danvillekidd
2013 ZL1
danvillekidd's Avatar
Drives: 2013 ZL1 m6
Are these going to work with the magride for ZL1s as well? Would be interested if they do.
danvillekidd is offline
Old 07-31-2014, 08:28 PM   #14
X25
X25's Avatar
Drives: '16 C7 Z51
What is the pricing going to be?
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD)
'13 Mazda MX-5 Club (Build Thread)
'17 RAM 1500 Crew Cab 4x4 Night Edition
'15 Nissan Rogue S AWD
X25 is offline
