06-02-2015, 11:36 PM | #1 |
Why cant I get the engine back in
3 of us fought for 5 hrs and could not get it the last 1/2" trany (M6) is in the car. I hope im not fing up the input shaft. bashed my finger good too. do i have to take the trany out?
06-03-2015, 05:48 AM | #2 |
Homeless Life Chose Me
Drives: LS3 (sold 4/21) Join Date: Nov 2014
Why was it out
06-03-2015, 06:47 AM | #3 |
Drives: 2011 1SS RS Camaro, 1995 LSX 240SX Join Date: Mar 2011
Pull the tranny and stab the whole thing as one piece. Lining up the clutch and input shaft is tough with the tranny already in the car if you don't have some practice.
2011 Camaro 1SS
Whipple Supercharged street monster |
06-03-2015, 09:54 AM | #4 |
Drives: 2015 LFX Auto Join Date: Apr 2015
Are you sure you properly aligned the clutch/PP plate when tightening the bolts on the PP? Sounds like your out of alignment slightly so the very end of the trans input shaft is not entering the pilot bearing properly. That would be the last 1/2".
When using an alignment tool you still have a bit of play so wiggle it each way and then judge the center of the play as your point to tighten the bolts. And always tighten them evenly criss crossing so it pulls the clutch plate in evenly. |
06-03-2015, 10:25 AM | #5 |
i did tighten it in a crisscross pattern with the tool. the tool will still go all the way in.
did a cam, lifters, oil pickup tube, Improved Racing oil baffle, and crank scraper. Aries the car is on stands so theres not enough room to put the engine and trans in the car together correct? I was thinking remove the trans and let it sit on the floor. bolt engine in then put trany in.
06-03-2015, 12:18 PM | #6 | |
2013 VR Camaro 2SS/RS LS3
Small, but effective mod list: Roto-Fab Intake, TSP 2" Long tubes, TSP catless mids, MSD spark plug wires, stock catback, Elite Catch Can, APEX washer relocation and scoop, VMAX throttle body, Diablo InTune-Tuned by Matt@FSP, and a JacFab license plate bracket. |
06-03-2015, 01:00 PM | #7 |
no but i thing the splines would have been in
06-03-2015, 03:22 PM | #8 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
if you have the clutch disc right ,then you twist right and left and up and down jiggling it while pushing it in with the trans out of gear. .
OLD GUY FLYING FAST AND LOW
06-03-2015, 03:29 PM | #9 |
That too...all I can think of
06-03-2015, 07:59 PM | #10 |
old school chevy rodder
some splines I have done on some different vehicle will have barely noticeable little welds in between a set of the splines so that a shaft will only go in in one position.......I would carefully look if your trying, but of course you if this is able..... to drop the drive shaft, I never put a engine in without removing the drive shaft then fitting it in last.?
06-03-2015, 10:34 PM | #11 |
im pretty sure the splines are all the same. cant get to it again until monday
06-03-2015, 11:04 PM | #12 |
Are you trying to drop the long block in? Or are you installing the heads and dressing in the car? You may be able to man handle it easier with just the short block
06-03-2015, 11:40 PM | #13 |
long block
06-04-2015, 12:22 AM | #14 |
I put a Monster Billet bearing support in. I was thinking should i open the remote bleeder. there's nothing but air in the slave.
