12-09-2019, 12:23 AM | #1 |
DO I NEED LIFTERS?
So I’m plan on camming my 2011 LS3 Camaro with 70K miles on it. I’m using a tick Performace stage 2 Cam 227/244 .618/.610 LSA 113+2. Do I need to replace my lifters as well? The shop told me that I don’t need to but I feel as if I should. Should I replace the lifters?
12-09-2019, 04:01 AM | #2 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
No, you don't NEED to replace the lifters. But it is cheap insurance for your new cam with your lifters having 70k on them.
More to come. |
12-09-2019, 06:02 AM | #3 |
Started#gottalovethatblue
On a LS3 you should be fine. If you had a L99 then yes. The answer is ALWAYS yes with a L99.
12-09-2019, 06:14 AM | #4 |
12-09-2019, 06:36 AM | #5 |
12-09-2019, 06:45 AM | #6 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
I’d do new lifters.
Sent from my iPad using Tapatalk
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
12-09-2019, 07:08 AM | #7 |
Drives: 2014 2SS/RS Join Date: Jan 2018
It's a choice really. Roll the dice. I didnt replace mine. Some people do and some dont. 100% of the people who do, wont regret it however some of the people who dont, will..
Sent from my SM-N960U using Tapatalk
2014 2SS/RS LS3/M6
12-09-2019, 07:16 AM | #8 |
12-09-2019, 07:32 AM | #9 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
If you are pullin the heads then YES 'cause your already there, if not then inspecting the cam lobes on the cam coming out will tell you what you need to do.
I put a cam with more lift in 2 yr ago with 75k plus miles on the motor and zero probs so far incl a sh!t load of drag racing. Just make sure to use a GOOD valve spring and correct P/R length. My P/R came in at 7.450 and I also use 3/8 p/r. I would also strongly recommend getting the rockers upgraded with bronze bushings. good luck! PEACE
12-09-2019, 07:52 AM | #10 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Yes, new lifters.
While the heads are off, send them to a machine shop for a .005" clean up deck pass, competition valve job and spring install. Aluminum heads will be off a few thousands when removed. Always do a clean up pass before a reinstall. Sounds like you are interested in the most insurance to avoid failure = new lifters, a good machine shop handling the heads, upgrade the cam core to a higher quality Callies core, new lifters... The better cam companies like Cam Motion will have options for the best core material. Off the shelf mass produced cams will have a variety of core hardness, thickness of hardness... and some turn into lobe peelers. Cheap cams are cheap for a reason. If your budget can handle a few more hundred, the Johnson drop in COPO lifters are top quality. Comp has a nice pushrod length checker tool to perfect the length. As mentioned before, bush the rockers. As long as the lift is below .620, bushed OE is fine. Roller tip needed if more lift. Upgrade the oil pump to a blueprinted one, be very careful with the O-ring. Prelube the engine to get pressure before starting it. |
12-09-2019, 08:44 AM | #11 |
Drives: 2010 Camaro 2SS/RS ABM 6M Join Date: Jul 2017
I only had 21k on my engine and still replaced my lifters. One of them had a small gouge that looked to have been caused by some kind of debris, and that would probably not have been a great thing to re-use. The cam matched though, so you can get a good gauge on your current lifters by inspecting the cam lobes from the cam that was pulled out.
Since it sounds like a shop is doing this, it would probably boil down to weather the heads were coming off for anything for me. If they are, I would just put new lifters in it since you are already paying for 95% of the labor there. If heads were staying on and cam looked fine, I'd probably just put a new one in and send it.
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
12-09-2019, 09:32 AM | #12 | |
12-09-2019, 09:39 AM | #13 |
Drives: 2012 ls3 Join Date: Feb 2014
My first cam (notice the key word "first") only lasted bout 20k due to lifter failure. After that shop told me no worries everything is just fine. I guess I'll rolled the dice wrong. The second shop that replaced that cam and lifters highly recommended LS7 lifters. And now I'm just a tad over 40k on cam.
12-09-2019, 10:56 AM | #14 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
IMHO, pull the heads, have them ported and make sure the guides are 100% and replace the lifters, springs, ,push rods, oil pump and timing chain and start fresh.
OLD GUY FLYING FAST AND LOW
