08-13-2020, 10:04 AM | #1 |
Drives: 2010 Camaro SS auto Join Date: Jul 2020
Kooks header install.
Hi guys I just got a set of kooks long tube second hand and having some trouble installing them. I got both sides of the long tubes on head but it seems the mid pipe connector is too long to mate with the factory exhaust, I will include a photo of what I mean.
Did I possibly buy long tubes for the wrong car and this guy “got” me or what’s your guys take on this? |
08-13-2020, 11:53 AM | #2 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Take off the rear part or the exhaust and then slip it on and hang the rear section on the hangers and it will more than likely work .
OLD GUY FLYING FAST AND LOW
08-13-2020, 12:08 PM | #3 |
Drives: 2012 ls3 Join Date: Feb 2014
08-13-2020, 12:28 PM | #4 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
What they said^^^^^
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
08-13-2020, 12:47 PM | #5 |
What him, he, and also Clark said ^^^^^^
08-13-2020, 02:06 PM | #6 |
Haha thanks guys it just seemed like it was too long no matter what way I did it. I’ll try to do the slip joins first and connect and see how it goes away work.
Sometimes it helps to just step away from it for a bit to get a clearer thinking. |
08-13-2020, 03:58 PM | #7 |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
are we going to be selling the shorty's you took off?
08-13-2020, 04:26 PM | #8 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
I little wd-40 on the rubber hangers work wonders.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
08-13-2020, 06:59 PM | #9 |
I have a set of JBA’s for sale in the for sale section.
Thanks for the help. Wasn’t sure if it was normal to have to push them back further like that. My stock exhaust does look like they cut the oem X pipe out and replaced mufflers as well so maybe they added some length to it without noticing also since it was chopped and welded up so much. |
08-14-2020, 01:11 AM | #10 |
Update- I ended up getting them fully installed tonight and it runs well, minor exhaust leaks at the slip joint from connector pipe to cat back area I will work on tomorrow.
Also, when installing the headers I seemed to overlook that these might be z28 headers from my research. It has a D port flange on the kooks instead of fully round? Also the connector pipe is 3” to 2.75”... was looking on sites and they all say “d port ls7 flange can be ordered for additional charge” on the kooks headers product page. Is there a major downside to me running these instead of traditional round if I don’t have leaks at the head? I’m sure there is but figured I’d still ask anyways. I did a lot of looking online and it seems d port heads use round headers no problem but I’ve never heard of them being used the other way around. Guess it’s my luck for buying used instead of ordering new ones... New to these cars but think I’m learning a lot reading about everything so far, trying to not get bummed out about these maybe being wrong ones after all but it ain’t the end of the world after all. Last edited by mreed055; 08-14-2020 at 01:43 AM. |
