Old 06-28-2011, 08:48 AM   #1
toilets
Drives: 2010 camaro
2nd Gear Clunk
I have been researching the forums and I cant seem to find this issue Im encountering... I see other threads about the trans/snychros as well as the launch control but not what im experiencing below.
When I shift from 1st to 2nd at the higher RPM range (5k or above) I get a huge clunk into 2nd gear. Like the car is saying no I dont want to go into that gear but if I must I will. You need some force behind it to get into gear. There is no grinding issue, just a clunk. Normal conditions, slow speed and low rpm shifts are all fine. This morning when I had to take the car to work, I pulled out into traffic and got on it till the 5k range.. shift and clunk into 2nd. All other gears are fine...
I first I thought it may be due to the hurst shifter since they are naturally hard to get into gear but it doesnt seem like it.
Question is has anyone experience this before? Is this normal? I know these trans are loud. I dont think Im doing it but could maybe pulling the gear to much to the left cause the clunk? The clunk seems to be coming from underneath/rear rather than right at the stick.
Any help would be great! thanks
toilets is offline   Reply With Quote
Old 06-28-2011, 08:49 AM   #2
toilets
Drives: 2010 camaro
Sorry, today wasnt the first time btw. It happens everytime into 2nd at a higher RPM range. I was just giving an example.
Old 07-08-2011, 01:01 PM   #3
CarbonCamaro
Drives: 2010 Artic White Camaro 2SS
I'm having the same issue even though I don't have the hurst shifter installed and would be interested in what the problem is.
CarbonCamaro is offline   Reply With Quote
Old 07-14-2011, 09:20 PM   #4
chriscamaro69z28
army life
chriscamaro69z28's Avatar
Drives: 2010 ABM camaro
im in the same vote here and iinstalled a hurst shifter be nice to know since we all seem to be discovering the same issue
chriscamaro69z28 is offline   Reply With Quote
Old 07-14-2011, 11:12 PM   #5
L99CAMA2011
L99CAMA2011's Avatar
Old 07-14-2011, 11:25 PM   #6
supersport11
Drives: 2011 2ss/rs
first time i shift outta first it always makes a weird noise then everytime after is ok...strangness
supersport11 is offline   Reply With Quote
Old 07-18-2011, 02:05 PM   #7
Chevrolet Customer Svc
Drives: GM Vehicles
supersport11, have you ever had your vehicle checked over to see what might be the cause of this issue? Thank you for your time.
Jeff Morris, Chevrolet Customer Service
Chevrolet Customer Svc is online now   Reply With Quote
Old 04-06-2012, 10:57 PM   #8
HardrockSS
Drive Fast Take Chances
HardrockSS's Avatar
Drives: 2012 45th anniversary SS
i got the same issue but 2nd to third it feels like a clunk
HardrockSS is offline   Reply With Quote
2nd gear grind??!! 11SynergyGr&Bl Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 12 06-24-2011 07:28 PM
2nd gear and Reverse of Fiero grind/won't go into gears. Any takers? Arachnyd General Automotive + Other Cars Discussion 0 03-20-2011 02:05 PM
VIDEO OF MY 505 RWHP CAMARO 1ST AND 2ND GEAR PULL SILVER BULLITT Camaro Photos | Spyshots | Video | Media Gallery 26 08-25-2010 08:34 PM
trying 2nd gear burnout 22" RS SS 5th Gen Camaro SS LS LT General Discussions 10 02-19-2010 11:21 PM
Does any 6 speed owners see a need for a gear indicator? OHIOSS 5th Gen Camaro SS LS LT General Discussions 98 10-13-2009 09:36 PM
