#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Road Course/Track and Autocross
Old 07-13-2020, 07:18 PM   #1
vr46
vr46's Avatar
Drives: 2019 ZL1 1LE
Best trailer for 2019 ZL1-1LE?
Hi...I read a few posts but nothing specific on this topic. Would love a light weight trailer, preferably under 22ft total for garage storage.
Main concern is how low the front is...don't want to damage while loading obviously. Would a tilt bed be necessary or the best option for this?
Love the drop down Futura trailers but at $15'ish, way to expensive.
Any help would be much appreciated.
vr46 is offline   Reply With Quote
Old 07-14-2020, 12:06 PM   #2
UrbanKnight
Drives: Fastish
the ZLE isn't "that low"... Race ramps are your friends... Tr7 ramps in addition to most trailer ramps, make it a no scrape affair...
Ive loaded into my enclosed many times... Althought I did have an airbagged trailers trailer that was the bees knees for low cars...
A sloans kwik load would also work well. Or an Aluma tilt with some ramp still needed
UrbanKnight is offline   Reply With Quote
Old 07-14-2020, 01:18 PM   #3
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
I am loading my car Thursday for a trackday Friday and will try and take a few pictures.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
Old 07-14-2020, 04:18 PM   #4
m3bs
m3bs's Avatar
Drives: '19 ZLE, S54 E36M3
As noted, ramps can be used as needed. Need to watch the deck width. I had a Featherlite 3110 that was 79” between the side rails, and it was nearly impossible to load the ZLE on. I ended up getting an Aluma 8218 tilt trailer that was slightly wider and no side rails so you can use the full width.
m3bs is offline   Reply With Quote
Old 07-15-2020, 07:40 PM   #5
Badmojo
aka BeastZL1
Badmojo's Avatar
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra
Aluma 8218 Tilt with some small boards for loading.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Badmojo is offline   Reply With Quote
Old 07-16-2020, 08:45 PM   #6
Ummpwr
Drives: Honda S2000
That's a really nice trailer and full set up!!
Ummpwr is offline   Reply With Quote
Old 07-16-2020, 08:59 PM   #7
m3bs
m3bs's Avatar
Don’t suppose you would be interested in swapping your stone guard for the high rise version?
Old 07-17-2020, 08:42 PM   #8
Badmojo
aka BeastZL1
Badmojo's Avatar
I like the low rise.
Sent from my iPhone using Tapatalk Pro
2019 Camaro ZL1 1LE
Old 07-22-2020, 06:42 PM   #9
Gator94
Drives: 2019 ZLE
I just got an Aluma 18 Ft trailer and had them fabricate a tire rack for about 1/2 the Futura's cost. Works great with race ramps.
Gator94 is offline   Reply With Quote
Old 07-22-2020, 09:53 PM   #10
Badmojo
aka BeastZL1
Badmojo's Avatar
I'm interested in the tire rack. Did Aluma do that or the dealer?
2019 Camaro ZL1 1LE
Old 07-24-2020, 12:02 PM   #11
Gator94
Drives: 2019 ZLE
The dealer did it for me.
Old 07-28-2020, 03:29 PM   #12
vr46
vr46's Avatar
Thanks for all the feedback and pics. Curious if any one uses a Kwik Load tilt trailer?(someone mentioned above)
I have a local kwik load dealer measuring the ramp to see if the ZLE will clear the front without the need of ramps. Might go with that one unless someone had negative experience.
Old 07-28-2020, 03:36 PM   #13
UrbanKnight
Drives: Fastish
Kwikload worked great on my zr1. Didn’t have it when I had the ZLE, but zle has more clearance than the zr1 had. I’d recommend the trailer anytime.
Old 08-02-2020, 07:45 PM   #14
ICTsccaCamaro
ITCRNRS
18' steel deck with a homemade rock guard and Etrack, I drive the truck up some homemade ramps and then also have homemade wood trailer ramp extensions just to make sure I don't rip the front bumper off when loading.
